03-06-2017, 12:30 PM | #1 |
1000hp is NEVER Enough!
Good Rocker Arms?
Hello,
Does anyone have experience with the Comp. Cams Ultra Pro Magnum™ Roller Rockers Part: 1678-16? I have upgraded my rocker arm trunnions to Straub already but, looking for a better rocker. At $375.00 they would seem to be a great deal and are rated at 850lb open spring pressure. Just wanted to see every ones thoughts and preferences for rockers, Thanks. http://www.compperformancegroupstore...Category_Code=
1,000hp IS NEVER ENOUGH!!!
03-06-2017, 12:41 PM | #2 |
Drives: 2010 Camaro 454 LSX (SOLD) Join Date: Jun 2013
We only use O.E. rockers on LS engines here or our trunion upgraded ones. Any time we have used a non o.e. rocker on a L.S. they rev less and are down on power. We back the cycle life on the o.e. unit down to 40-50K with the increased spring pressures.
03-06-2017, 01:02 PM | #3 |
ZL1 Pilot
This is my preference. I don't care much for comp valve train parts
GP Tuning 2.5 Cam, RPS Carbon Twin Clutch, Ported Blower, Kook's Headers, Cold Air Inductions CAI, ID850's, 9.17 Lower, 2.5 Upper, JMS BAP, Pedders Front Radius Arm Inserts, Whiteline Subframe Inserts, Tuned by me with HP Tuners Idle Clip Link...........https://www.youtube.com/watch?v=gTL8S9eHwbs |
03-06-2017, 01:20 PM | #4 | |
Drives: 2015 ZL1, Red Hot A6 Join Date: Aug 2016
2015 Red Hot ZL1, Rotofab, Kooks LT's, 10" lower, ID850's, JMS BAP, BTR stage 3 torque cam, meth injection, self tuned with HPtuners
1969 Chevelle, 418 LS3, Ridetech suspension |
03-06-2017, 03:22 PM | #5 |
Drives: 2014-ZL1-M6-CRT, 68 camaro SS 496 Join Date: Feb 2012
Im not sure why you would upgrade to an aftermarket rocker when you already have the trunion upgrade?..Unless you are turning the wick way up with a solid roller and high spring pressure, shouldnt the stock rockers with the upgrade be sufficient?
With that being said. Ive used comp rockers on SBC/BBC stuff and never had any problems...Crane i an OEM manufacturer of rocker arms, so i would say if going aftermarket, look at Crane Cams arms, if they make them for LS stuff.
2014- Crystal Red-ZL1 #1601, M6, Recaro, sunroof, Nav-stock-SOLD
1968 Camaro SS Clone- 496 BBC, Legend 5speed, 12 bolt 1970 Nova SS- 383 SBC 588hp, 200-4r, 12 bolt |
03-06-2017, 08:26 PM | #6 |
Drives: '21 ZLE A10 Join Date: May 2012
T&D rockers are used in the COPO LS7...must mean something!
03-06-2017, 09:06 PM | #7 | |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
The bronze bushing trunion upgrade is plenty for stock to mild cams. Like mentioned before... lift will drive valve train parts choices. The beauty of the stock rocker is low tip weight. The horror is the needle bearings and pot metal tin holding them in. If your lift is reasonable...bronze bushings...done. Those T&Ds are sweet. And I too love it when someone else spends their millions in R&D to find what works....thanks team COPO. I asked one of the engineers once at a trade show what lifters were in the COPO motor... Johnson, part #*******. Said those were the only ones that made it through validation. Thanks for the free R&D. I can't afford a spintron machine with high speed camera $$$$$$$$$$, but I sure know how to ask those who do. Katech is another good one to keep an eye on for what parts to use. They do all that endurance racing stuff and have the high dollar test equipment. There are plenty of parts that might work... then there are packages that have been tested to death to find what really has valve train stability. That uber high speed camera pointed at the valve seat don't lie. |
03-07-2017, 04:15 AM | #8 | ||
Thank You!
Thank you everyone for the feed back. I looked up the CHE bushing kit, wish I would have come a crossed it first. I am making 780rwhp approx. 900hp at the crank.My parts list is in my photo albums. I was wondering if there was anything better. Glad to see I am on the right track. Comp Cams came out with a new upgraded stock LS rocker at the 2016 sema show. Looks like what everyone was saying about stock rockers being great in engine build ups. If you can't beat them join them.... Part Number 1978-16... $500 with needle bearings and $600 with a thin solid bushing. Will consider them when I hit 50,000 miles, would be nice if I could use with a CHE bushing kit. (I asked CHE but they have not tried them, Yet)
03-07-2017, 04:27 AM | #9 | |
Lifters?
I was thinking of these Johnson P/N: ST2126LSR or ISKY P/N: 2078HYRT. Right now I am running stock lifters, I have not pulled my heads... (Yet) But when I do, I want to be ready.
03-07-2017, 04:19 PM | #10 | |
'It's an experiment'
-Don
747 RWHP 794 RWTQ
03-09-2017, 08:15 AM | #11 |
Does anyone know... if you have stock LS3 rockers with the Comp Cam trunion upgrade kit... can those same rockers be converted to the CHE bushing trunion kit? Or would it be better to start with new OE's and do the CHE to those?
03-09-2017, 08:20 AM | #12 |
ZL1 Pilot
Yes. The CHE version is machined. Then bushings pressed in. Then they go through a magnetic particle inspection for cracks and defects in the metal.
03-09-2017, 08:21 AM | #13 | |
I know for a race car, they steered me toward... short travel, tie bar, axle oiling, race. |
03-10-2017, 11:47 AM | #14 | |
Lifters
