10-12-2015, 10:14 AM | #1 |
Drives: 2010 Camaro SS 5th Gen 6spd SC Join Date: Jun 2015
Easy way Install rear cradle bushings? anyone try this tool kit?
A shop charges way to much for this job... so I was thinking about doing it at home.
I did find this - http://www.ridetech.com/store/2010-2...tion-tool.html
10' LS3 Camaro 2SS (blacked out) - Edelbrock Supercharger, ZL1 rims, 275/315 tires, XS Power LT headers, 3" exhaust, twin tips, Edelbrock CAI, ZL1 fuel pump/ADM FPCM, VMax ported TB, JRE fuel mod, TR6ix plugs, ZL1 spoiler/splitter/grille, KW V1 coilovers, BMR sway bars, strut tower brace, trailing arms, toe links, Prothane radius arm & subframe bushings, Slotted rotors, Hawk pads, SS brake lines, HURST short throw shifter, Scosche dash kit, Pioneer 7" radio, backup camera, Dyno - 520 rwhp/tq
10-12-2015, 10:38 AM | #2 |
Drives: Camaro Justice Join Date: Jun 2007
The tool will work, but it isn't necessary.
Set the cat on jack stands Place a floor jack under the diff and raise it to hold it in place Remove both wheels Remove all four sub-frame bolts, one at a time, and replace them with a 1/2 of thread. This leaves the sub-frame free to move. Remove the lower shock bolts Disconnect the sway bar endlinks Remove one bolt and insert a socket between the ferule of the bushing and the 'frame' Use a second jack to put pressure on the bushing by raising the jack on part of the sub-frame or an arm. You now have a press. Lightly heat the sub-frame to release the glue that holds the bushing in place. Heat and add a pump to the jack, heat again, until it falls out. Install the new bushing Loosely install the bolt Repeat Last edited by JusticePete; 10-13-2015 at 10:19 AM. Reason: Added more for clarity |
10-12-2015, 11:45 AM | #3 | |
10-12-2015, 12:32 PM | #4 | |
Do you use two jack stands at the factory jack points and use 1 jack under the rear diff? Do you raise the rear diff? How do you lower each side to get room between the rear cradle and the car to access the bushing? Thx
10-13-2015, 08:43 AM | #5 | ||
You raise and lower the sub-frame with the jack under the differential. Lower the jack stand and tip / tilt the cradle to the side that you are working on. |
10-13-2015, 09:16 AM | #6 |
Drives: 2010 camaro ss Join Date: Jun 2010
Remove the metal caps with a pry bar or a long screwdriver. They just pop off. Much easier when they are still installed.metal caps are the ones on the bottom of the bushings. Get somebody to help out. It'll be much easier
10-13-2015, 09:18 AM | #7 | |
Easier is relative to the tools at hand. |
10-13-2015, 09:46 AM | #8 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Watch out if using a pry bar. Almost got hit in the face with it when a friend and I installed inserts on my rear subframe. Also a torch is your best friend when removing those plates as well. Heat up the center a good bit and they should pop off.
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
10-13-2015, 10:15 AM | #9 | |
found Heat method video:
10-13-2015, 02:57 PM | #10 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Pete I'm sure you have addressed this before but for a street and occasional track car would you recommend Poly, Solids (Delrin or Alum), or possibly the Z/28 1LE pieces???
10-13-2015, 03:04 PM | #11 |
Drives: 2012 Camaro 1LT/RS Join Date: Jun 2015
Does the exhaust need to be removed ?
2012 Camaro 1LT/RS Black with Cyber gray rally strips. CAI, Elite Catch Can, Vitesse Throttle controller, BMR Sway Bars, Strut tower Brace. |
10-13-2015, 03:32 PM | #12 |
Drives: Race Car Join Date: Sep 2009
10-13-2015, 04:21 PM | #13 |
Ed
Drives: 2013 AGM Camaro 2SS/RS/1LE Join Date: Dec 2012
I didn't have to. But found it helpful to dismount the exhaust from last two exhaust hangers on each side to give me enough room.
10-13-2015, 04:35 PM | #14 |
Bushings
Thread Tools | |
