01-27-2020, 08:49 AM | #1 |
Drives: 2010 Camaro SS Join Date: Jan 2020
I have decided on AGP.
But now the hard part is here. I am looking for top quality and prefer Ball Bearing. I'm looking at Garret 3582r Turbos or EFR 7670 57/58 (fast spooling). Does anyone have any advice.
01-27-2020, 11:30 AM | #2 |
Drives: 2015 Camaro SS commemorative Join Date: May 2015
baby sized turbos, you will be disappointed and have back pressure issues if you ever decide to turn it up . Fast spooling is great but you will rob your top end of potential.
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
01-27-2020, 12:14 PM | #3 |
How much HP do you get with the twin 68s? So no turbos under 60mm and the fast spooling will lower top speed and time.
01-27-2020, 12:57 PM | #4 |
I've got my twin 65/65 @ 23lbs making about 1350rwhp
2012 Camaro SS Automatic
AGP Twin Turbo LSX427 / ADM Magic / 4L80 “1360 Rwhp 1225 Rwtq 25 lbs of boost” |
01-27-2020, 12:58 PM | #5 |
Drives: All things Turbocharged Join Date: Dec 2010
What are the engine and trans specs? Use of the car?
01-27-2020, 02:11 PM | #6 | |
Drives: 2009 ZR1 Join Date: May 2010
I then got a set of BB 65s. I made 27# but boost would fall to around 21#. I made 122x with them. After I got the boost issue fixed, I never re-dynoed. I sold the car to a friend. He made 1189whp on low boost (16#) I believe. Mine and Scuzz's setups were very similar except he is an auto and I an M6. You made the right choice with AGP. I don't even have a twin turbo car anymore and I still pimp them! |
Thread Tools | |
