03-02-2016, 08:30 AM | #1 |
Drives: '13 1LE, '89 Caprice Join Date: Jul 2013
Highly oxigenated fuel
Anybody use highly oxigenated race fuel, like EXO2? Can the 1LE fuel system handle the increased fuel flow required without going lean? I'm guessing the pump is fine since it's from the ZL1, but I wonder how the injectors would handle it. I think it requires an extra 5% of fuel due to the oxygenation. I'm just wondering in case I do a track day and want/need to fill up with race gas. I'd also be interested to see dyno comparisons with street gas. They say it can increase power by 3%.
03-02-2016, 11:53 AM | #2 |
Drives: 2013 1LE camaro Join Date: Apr 2013
I'll be the one to break your heart and not really give you the answer you want to hear. If you're not tuned on race fuel.. You are pissing away your dollars in the tank. Based on premium (street gas) should be high enough octane to compete in any track day. Sure the higher the octane will help with "pinging" or "detonation" if you're having any of those issues I would look into the fuel you're filling up with per say. But you won't see any extra benefits of filling up with race fuel w/o being tuned on it. Ie adding timing to the calibration to be more aggressive with said fuel( race gas)
03-02-2016, 12:02 PM | #3 |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
The 1LE's also have the ZL1 injectors I believe
UPSTATE C5 MEMBER
03-02-2016, 04:24 PM | #4 | |
Drives: 2013 1LE RS 1SS Join Date: Apr 2009
lost 15whp on 110 oct. tuned we got it all back plus 3 whp I say not worth the money |
03-03-2016, 08:07 AM | #5 |
I know the higher octane won't help me, but with more oxygen in the gas (10% by weight) it'll burn more gas. It's supposed to act as a very weak supercharger or turbocharger allowing you to burn more gas per cylinder, adding 10-20 hp. Now that's just what I've heard and read in a lot of places and I completely understand that anything over 93 octane won't help me.
03-03-2016, 08:11 AM | #6 |
That's interesting. Do you have any idea of what caused it? Was it running lean and the standard tune wasn't spraying more gas?
03-03-2016, 08:13 AM | #7 |
03-03-2016, 08:29 AM | #8 |
The factory tune is only as good as its from the factory. It won't pick up that you're using anything over 93 or 91 whatever is a available in your area (premium) whatever fuel you use its only to go run on that. Just cause it has ZL1 injectors doesn't mean anything. The duty cycle are already predetermined based on the factory tune. Unless you are going to TUNE( efi live, hp tuners, etc...) to change the duty cycle and how much fuel is being injected to the Cylinders at given points once again still a waste of money
03-03-2016, 11:46 AM | #9 |
Ok, so it sounds like the factory tune isn't smart enough to see the O2 sensors reading that lean and increase the injector output by 5%. That's what I needed to know.
03-03-2016, 04:52 PM | #10 |
03-03-2016, 05:19 PM | #11 | |
Tri-County Camaro SWFL
Like a few have said, race gas is useless for performance gains on a factory tune. BUT if you get bad gas and you datalog and are reading knock retard, using race gas can cure KR readings. It can hurt and it also can help. Just depends on your situation.
