09-04-2015, 08:44 PM | #1 |
They call me captain slow
Drives: 2010 camaro lt Join Date: Jun 2010
Not starting issue
Yeah I have a 2010 camaro and I'm having a starting issue right after I fill the gas tank up, it cranks but won't fire but eventually will, and it only does after you fill the tank up with gas. I put new plugs in it and gapped to .40 and it helped for a little bit but it's back doing it again. Is the gap wrong? Is it the fuel pump? I had the timing chains replaced as I was having a check engine light with them and didn't have the issue of this odd staring issue to now, what could be the problem? No cel and the car runs great
09-04-2015, 10:30 PM | #2 |
Jus' Cruzin
Drives: 2017 Camaro 1SS Krypton Green Join Date: Oct 2012
Sounds like the fuel pump to me.
“The moment you think you know what’s going on in a women’s head, is the moment your goose is well and truly cooked”
-Howard Stark |
09-04-2015, 10:33 PM | #3 |
Oh boy, theres a 1000 bucks
09-04-2015, 10:42 PM | #4 |
Ok, I can get one for 110, I wonder how hard it is to drop the tank
09-05-2015, 10:44 AM | #5 |
Drives: 2010 Camaro 1LS 3.6 LLT V6 325 HP Join Date: May 2009
Guys on the forum do it.
http://www.camaro5.com/forums/showth...89#post5708189
09-06-2015, 10:52 AM | #6 |
The Milano
Drives: 2017 Firefly ShipWorks Join Date: Jun 2010
Mine has done this a few times a few years back - on really hot days. If you shut it off and try to start it a few minutes later it wont start. Once it cools a bit - starts right up. I chalked up to vapor lock. fairly common issue.
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter. |
09-07-2015, 12:18 PM | #7 |
Why would it just start now? I'm not doubting you formare
09-07-2015, 04:02 PM | #8 |
redleader
Not starting issue
09-07-2015, 06:51 PM | #9 |
It has been hot and humid and it does it at two places I get gas at
09-08-2015, 04:47 AM | #10 | |
Drives: 2014 2SS/RS Camaro Join Date: Dec 2014
Dropping the tank is a PITA. There is a thread here where someone pulled the rear seat, cut a hole in the floorpan right above the fuel pump, then fabbed a nice cover for the hole. Using this hole/cover you could literally replace your pump in about ten minutes. If mine ever goes bad, this is what I plan to do.
2014 2SS/RS, L99, SW LTH w/HF Cats, GMPP Ex. Z/28 CAI, FR41s in PVD Black Chrome, Recaros, Pfadt Sway
377hp, 383tq 12.739@110.44 MPH |
09-08-2015, 08:03 AM | #11 |
Yeah I found the thread, it will have to wait after vacation as I'm not taking this car on vacation anyways
09-11-2015, 08:08 AM | #12 |
Would a fuel pump going bad make have a burbling at start up through the air filter system? It's a k&n cai? I hope it's just the fuel pump being weak? I refuse to have the timing chains redone again after I had it fixed under warranty and now my warranty is up. I'm not paying out of pocket to fix what the Chevy dealer already fixed. As my check engine light came on afterwards
09-11-2015, 04:48 PM | #13 |
Had code checked it's got a miss I don't know if it's coil or plugs, I replaced the plugs and gapped them to .040 and I disconnected the coils on every cylinder and they make the engine want to shut off, I plugs I ordered from rockauto was slightly longer. Would that make a difference?
09-14-2015, 06:19 AM | #14 |
Jus' Cruzin
You may have water in the tank too..Try some Heet first and see if that helps.
-Howard Stark |
