05-05-2018, 12:39 AM | #1 |
YOOZ GOTA B FREKN KIDN ME
2013 ZL1 LSA Misfire/Hesitation. PLEASE HELP! I need expert advice
I have an intermittent misfire/pop/hesitation on my 2013 LSA powered Camaro ZL1. She has 18,000 miles on her. Only mod is a Hooker cat back 3" dual exhaust with xpipe no mufflers and a K&N drop in filter with no tune yet.
The problem seems to be limited to and occur only after coasting downhill with sustained low RPM engine braking. When it's time to accelerate again seems if I give it a decent amount of throttle starting from 2500 RPMish and put a good load on it I get a Misfire/Pop/Hesitation at about 3000 RPM. Then it seems to be okay again until I repeat a similar scenario. I am a novice DIY mechanic. Any ideas, suggestions, solutions would be much appreciated.
The Zeldabeast! A True Road Warrior!
2018 Dodge Challenger Hellcat WideBody 6MT 2013 ZL1 Camaro 6MT 2015 GMC Sierra 1500 SLT 6.2 L86 Crew Cab 2012 Aprilia RSV4 R 2015 Husqvarna FC450 Motomadness First Car: 1973 Dodge Charger 340 Magnum 4MT Factory Hurst Pistol Grip Shifter Last edited by Zee-Ell-One; 05-05-2018 at 01:13 AM. |
05-05-2018, 06:21 PM | #2 |
Drives: 2013 ZL1 Join Date: Jun 2015
Easiest thing to check, that I have seen more than once is damaged spark plugs and/or damaged spark plug wires or loose spark plug wires.
05-09-2018, 10:07 AM | #3 |
OP here, I replaced the plugs and it fixed the problem.
Apparently as well as gas and oil, LSA engines like to dine copiously on spark plugs as well. I guess $50 in spark plugs every 18,000 miles ain"t so bad. Pay to play!!
2018 Dodge Challenger Hellcat WideBody 6MT 2013 ZL1 Camaro 6MT 2015 GMC Sierra 1500 SLT 6.2 L86 Crew Cab 2012 Aprilia RSV4 R 2015 Husqvarna FC450 Motomadness First Car: 1973 Dodge Charger 340 Magnum 4MT Factory Hurst Pistol Grip Shifter |
05-09-2018, 11:40 AM | #4 | |
Drives: 2013 VR ZL1, M6 Join Date: Nov 2017
If the plugs went or looked in bad shape, I'd look at other things that may have caused it. Such as running too rich, bad gas, modifications that alter the tunes parameters, etc. Not saying you have these issues, but it's worth it to take a look.
#3257 | 485whp 526wtq | K&N 63-3079 | Gates K080660HD (Green Belt) | ACDelco UPF48R | ZL1 Addons Wicker Bill | Mild2Wild
05-09-2018, 08:08 PM | #5 |
Drives: 2013 camaro zl1 Join Date: Feb 2016
I had same problem a few months ago. Replaced spark plugs. Runs perfect. Good luck
