#Camaro6
Old 06-14-2018, 08:46 PM   #1
Flashyeezus
SS
Drives: 2018 ss
Is the Vette and ss the only cars with the 6.2l lt1 engine
Do any Chevy trucks etc have that same engine or is it specifically only the c7 and 6th gen ss.
Flashyeezus is offline   Reply With Quote
Old 06-14-2018, 08:53 PM   #2
jdasnt3
jdasnt3's Avatar
Drives: 18 Silverado 1500
It is an option in the Silverado LTZ 1500 and you can get it in the 2500. Should be an option for the Suburban in 19, I believe.
16 Red Hot 2SS A8: NPP, CAI Cold air, Ported TB, Fasterproms Ported intake, E85 flex, Formatto tuned. 11.80@118 with 1.92 60' (600-700 DA) on stock run flats.
jdasnt3 is offline   Reply With Quote
Old 06-14-2018, 08:55 PM   #3
Bhobbs
Bhobbs's Avatar
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle
The truck engine is different. The only vehicles with the LT1 are the Corvette and SS.
Bhobbs is offline   Reply With Quote
Old 06-14-2018, 09:18 PM   #4
Cgocifer
Cgocifer's Avatar
Drives: 2018 1SS 1LE, 2015 RAM Ecodiesel
Any Caddilacs?
Cgocifer is offline   Reply With Quote
Old 06-14-2018, 09:42 PM   #5
Number 3
Hail to the King baby!
Number 3's Avatar
Originally Posted by Cgocifer View Post
Any Caddilacs?
Nope.
Old 06-15-2018, 06:15 AM   #6
mdhopt36
Drives: '17- 1ag37 V6 traded, for 1SS 2018!
My previous 2017 1LT and my wife's Caddy both had 3.6- V6's, but in no way, shape or manner were they the same. Not by a long shot.
I strongly suspect the same thing with 6.2 truck motors---being neutered; no snap.
mdhopt36 is offline   Reply With Quote
Old 06-15-2018, 06:18 AM   #7
SecondZ28
SecondZ28's Avatar
Drives: 2013 ZL1
Any Caddilacs?
Only the LT4
'13 ZL1
'06 TBSS
'98 TJ
'87 GN
SecondZ28 is offline   Reply With Quote
Old 06-15-2018, 06:35 AM   #8
JT58
Drives: Former 2016 Camaro 1LT
Any Caddilacs?
I thought it was in the CTSV.
2006 C6 Corvette Manual, 2019 Silverado, 1997 Jeep Wrangler
JT58 is offline   Reply With Quote
Old 06-15-2018, 06:37 AM   #9
fastball
Banned
Drives: 2017 Camaro 2SS 6MT
The truck version of the 6.2 is engineered and tuned for hauling and trailering, the Camaro (and Corvette) version is obviously tuned for performance. Those are two very different intended uses, which reinforces the fact no one should be using their Camaro to trailer anything. Even a crate with an extra set of tires for the track. Nothing.
There's a few threads on here where people are asking about trailering with their Camaro, their thought process being "it's the same engine that's in the trucks so it must be ok to hook a trailer to the Camaro". No, it isn't. Big no-no.
fastball is offline   Reply With Quote
Old 06-15-2018, 07:51 AM   #10
TJay74
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC
Actually this is not fully correct. The truck 6.2L engine is the exact same as the Corvette/Camaro. Same block, rotating assembly, cam and heads. The only difference on the truck engine is the intake manifold, throttle body and exhaust manifolds.
TJay74 is offline   Reply With Quote
Old 06-15-2018, 07:53 AM   #11
TJay74
The 6.2L engine in the Corvette/Camaro has no bearing on if the vehicle can tow, it is the car itself that determines that. It is a function of what weight the frame system can handle, are the brakes able to handle the extra load and so on.
The engine in the cars make a little more power and torque than the truck engine and it is just a bit higher in the RPM range, but the car engine is more than up to handling towing.
Old 06-15-2018, 08:02 AM   #12
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Any Caddilacs?
Nope.
Now, Cadillac has the LT4 in the CTS-V.
The L86 used in the GMT K2xx platform is the same 5th gen small-block family, I think it's fair to say it's close enough to count here, as the main differences are the intake and exhaust manifolds, and tune, which aren't part of the long-block.
oops, TJay beat me to it.
2017 "M1SS1LE" in Hyper Blue w/PDR
Ryephile is offline   Reply With Quote
Old 06-15-2018, 09:21 AM   #13
Bobkd
Drives: 2018 1ss, 2021 silverado HD
It's not in the 2500's only the 6.0. I wish it was, they need a stronger gas engine option.
Bobkd is offline   Reply With Quote
Old 06-15-2018, 09:15 PM   #14
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
this + tune and you can not get a 6.2l in a 2500 or suburban. you can get it in the extended cab and crew cab 1500 LTZ and the Tahoe RST. you can get it in the GMC Sierra 1500 and Yukon
JCunningham is offline   Reply With Quote
