Old 02-19-2020, 11:26 AM   #1
xqwzit
xqwzit's Avatar
Drives: 2011 SIM 2SS/RS 6M
New build... won't start
Getting code P0016 changed both cam and crank sensors, new battery. Have spark, fuel, etc and found pic from build timing sockets are correctly lined up. Any thoughts?
Rebuilt engine, all new, C5R timing kit, TSP stage 2 blower cam, 2.9 whipple, 102TB, ported/ polished heads,
xqwzit is offline   Reply With Quote
Old 02-19-2020, 11:36 AM   #2
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
What did you do too it?
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 02-19-2020, 11:44 AM   #3
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
check broken or worn out or broken timing chain tensioner. worn out sloppy chain.
Greenhornet2 is offline   Reply With Quote
Old 02-19-2020, 11:52 AM   #4
LsxDoctor
15 Year LS1Tech Member
LsxDoctor's Avatar
Drives: 2010 ss 391ci LS3
I've seen a bad chain throw this code before. Also make sure timing marks are lined up correctly. Did you degree your camshaft when installing?
Check for pinched/melted/damaged wires too
GJDM
LsxDoctor is offline   Reply With Quote
Old 02-19-2020, 12:27 PM   #5
xqwzit
xqwzit's Avatar
Ive added mods to OP and have checked wiring for loose connections and broken/ damaged wires.
Old 02-19-2020, 12:48 PM   #6
InFiD3ViL
InFiD3ViL's Avatar
Have you gone back over every single grounding point? One of the easiest things to forget is one of our many grounds.
Every point marked with a '2' is a ground location. Obviously a bit different since you have a blower on top, but close enough.
Old 02-19-2020, 01:41 PM   #7
xqwzit
xqwzit's Avatar
I have and did find one that wasn't connected. Which was reason it wouldn't crank. I will use this schematic when I get home to go over things again. Thx
Old 02-19-2020, 01:54 PM   #8
HOU_TX_SS
Drives: Camaro SS
I've been through a similar situation like this before with my trailblazer SS, and it was a ground.
Fully Built 416ci / Procharger F1X / Century Built 4L80 / ZL1 Differential / Alky Control Meth /Circle D Triple Disk / ID1300s / Fore Innovations Return / Kooks Full Exhaust / Holley HiRam / e85 / 15in Conversion on Forgestar Beadlocks / Tuner: Pat G
HOU_TX_SS is offline   Reply With Quote
Old 02-19-2020, 07:00 PM   #9
xqwzit
xqwzit's Avatar
Checked all grounds again still won't go
Old 02-19-2020, 07:58 PM   #10
CamaroBarb
Banned
Drives: cheby Camaro
Are you using the cam phaser? If you are its not full of oil yet causing the cam timing to be all over the place. Crank it until you see oil pressure.
CamaroBarb is offline   Reply With Quote
Old 02-20-2020, 08:24 AM   #11
xqwzit
xqwzit's Avatar
My car is a 6 speed manual
Old 02-20-2020, 09:04 AM   #12
HOU_TX_SS
Drives: Camaro SS
Pain in the ass, but if I were you I would get the technical manual and use the wiring schematics and diagrams. I've done this when moving my fuse box and did every single pin to every sensor in the entire car. I have the manual if you need it in pdf form.
Old 02-20-2020, 12:02 PM   #13
xqwzit
xqwzit's Avatar
Yes if you could email it that would be great. xqwzit99@hotmail.com
Old 02-20-2020, 12:38 PM   #14
HOU_TX_SS
Drives: Camaro SS
I sent you a link to google drive. File is too large to send.
