02-10-2015, 10:21 AM | #1 |
V6 wheel question
I'm so close to pulling the trigger on wheels! I'm stuck between a set of 19" and the lg motorsports replica wheels. The steelies I have now are about the same weight as the replica wheels. I know I will see a difference in handling, but will the bigger wheel affect negatively on the low end acceleration being a 20" rather than an 18"?
02-10-2015, 11:07 AM | #2 |
Guest
You'll have more rotational inertia due to the weight spread out over a larger diameter but I doubt it'll make a noticeable difference. You will have more unsprung weight since your tires will be larger.
02-10-2015, 03:03 PM | #3 | |
INFECTED
Drives: 2011 1LT Synergy Green Join Date: May 2011
02-10-2015, 03:47 PM | #4 |
Turns out that the 19" that I was looking to buy just aren't deep enough. so I found a set of 20" Motegi MR127 wheels that have a perfectly deep convexity to them..buuuttttttt.. They weigh about 35-38 pounds each. That weight will make a highly noticeable dent in the low end acceleration wont it? If so I think I've made up my mind on the replica wheels.
02-10-2015, 04:45 PM | #5 | |
*Performance:
mrt v2.0 exhaust/CAI Intake *Cosmetic: Zl1 factory Reproduction wheels Bmr 1.2/1.4 springs/Oracle plasma drl lights, footwell ambient lighting, 45th Gobo lights *Audio: Memphis pr600 amp/Fosgate 12" t0 sub/******** stealth box |
02-10-2015, 05:22 PM | #6 | |
I only looked briefly, but I could not find any factory that where cheaper than the LG. If you could point me in the right direction for them that would be great! I need all of the help I can get. Thanks a lot! |
02-10-2015, 05:57 PM | #7 |
No problem at all that's what c5 is here for! Search the name factory reproductions on the forum it will give you the pricing and sizes your looking for. These aren't factory oem they are "fakes" such as lg but very good quality and customer service is amazing. I've had them on my car for over 6 months and have had people say they like more than the stock zl1 wheels. Any other specific questions you have feel free to ask.
*Performance:
02-11-2015, 11:28 PM | #8 | |
INFECTED
Make sure you have the right off set for your wheels , When I bought my new wheels I had to go with 38 mm off set.
02-12-2015, 10:25 AM | #9 |
The motegi wheels that I am looking at right now are +25 in the front and +28 in the rear. Car id guarantees the fitment but I guess they don't say how well it will fit. do you think I may have an issue with these offsets when I go to put them on?
02-13-2015, 09:44 AM | #10 | |
Do you think I could go 19X9.5 +35 squared with no issues in the front? I've seen a few people saying yes and a few saying know. |
02-13-2015, 09:48 AM | #11 |
Nightmare
Drives: Your mom crazy in bed Join Date: Mar 2011
One thing I believe you are overlooking is the price of the tires, as tires are expensive for 19's and 20's.
If you are truly concerned with performance, I'd be looking to stay with an 18" wheel...
02-13-2015, 10:09 AM | #12 |
Thank you for pointing that out! I found wheels that I want that are much lighter than the steelies and in 19x9.5. just not sure if I could fit the +35 offset up front.
02-15-2015, 12:38 PM | #13 | |
INFECTED
I'm still learning to. The easiest way I figured it out . I did a wheel & tire package deal to get it all right, they did the T p m s sensors mounted & balanced the wheels. And shipped them all for one price.. So in the end take my old wheels off & stick the new Wheels on ..Easy swap .. I also did forget, I had to have new lug nuts also for new wheels , they came with them also Stock lug nuts would work ..
02-16-2015, 08:16 AM | #14 | |
Thanks for your help! I really appreciate the input |
