04-19-2016, 04:44 PM | #1 |
AquaRob
Drives: ABM RS\SS; 69 427 Camaro; 1970 Z28 Join Date: Mar 2010
FORE Twin Pump Setup
All,
Relisting this as I held on to it the last time I had it listed because I was going to use it after all. I bought this twin FORE setup over a year ago, never took it out of the bag until last night just to take pics and verify pump size, but am in need of a bigger setup. This is the previous generation, non-black anodized, and is for GAS and RACE GAS only. Not recommended for E-85, which is where my build is headed. You could always switch out to different pumps later on to make it E-85 compatible but my build will require a larger setup. Link shows pricing for comparable setup with same pumps. http://www.foreinnovations.com/Produ...uctCode=43-800 Initial link does not show upgraded pumps. Setup has the Walbro TI - 262 pumps. Comes out to $745 on their site. Asking $625 shipped anywhere in the lower 48. Thanks I will also be listing some ID2000 injectors that have zero run time since I had them cleaned and re-flowed at Injector Dynamics, as well as a set of Black Holley LS fuel rails that are also new. I opened the package for some mock-up until I decided to do a custom manifold and rail setup.
Centerline, Weld, Holley, Nick Williams, GMPP, Diamond, ARP, Callies, Nelson Racing, Pro Torque, Strange, J&S Polishing, RMCR, AAC, MBRP, Flowmaster, FAST, Comp Cams, RX Performance, Aeroquip, Spectrum Powder-Coating, Current Performance, RX,TDub Racing, DSS, Fore Innovations, Aeroquip, Earl's, BMR, Ximpac, MPD,Street Scene, Blood, Sweat and Tears
04-19-2016, 05:21 PM | #2 |
Drives: 2011 Camaro 2ss M6 Join Date: Mar 2012
What kind of power are these rated at?
04-19-2016, 05:36 PM | #3 |
AquaRob
04-19-2016, 11:50 PM | #4 |
Drives: 2010 SIM Camaro 2 SS/RS Join Date: Apr 2013
any fittings for the feed and return? and how much for the id 2000?
2010 2SS/RS LS3/M6 SIM. More money than I want to think of in mods.....
04-20-2016, 10:06 AM | #5 | |
AquaRob
I'm asking $1650 for the ID2000's. Flowchart is listed on the post. Thanks
04-20-2016, 12:40 PM | #6 |
What are you asking for the fuel rails? And size is the ends?
04-20-2016, 02:03 PM | #7 | |
AquaRob
Thanks
04-25-2016, 10:31 AM | #8 |
AquaRob
Monday Bump
04-25-2016, 11:01 AM | #9 |
Still curious on the fuel rails
04-26-2016, 10:37 AM | #10 |
AquaRob
thanks,
If I pull my head out, I will upload details tonight. It's been super busy and I keep forgetting.
04-27-2016, 03:01 PM | #11 |
AquaRob
Here are the fuel rail pics. Looks like I bought them specific to the Holley Hi-RAM. These will also work on the single plane aftermarket intake.
Rob
05-02-2016, 09:54 AM | #12 |
AquaRob
Monday bump
05-09-2016, 05:01 PM | #13 |
AquaRob
Bump
05-09-2016, 05:25 PM | #14 |
Too much is never enough!
OMG you still haven't sold this yet? I'm surprised, its a good price, and a good deal. If I had not just emptied my wallet on my engine, I would have scooped this up for sure. GLWS!
