Jason 98 TA
Old 06-26-2013, 04:34 PM   #1
mwt18
mwt18's Avatar
Drives: 2010 Camaro 2SS
DEMODDING SALE: Kooks LT Headers & Cats, PLX AFR Module, DS Trinity, MSD FPVB, & MGW
I removed all this stuff before I traded in my Camaro. Everything is in excellent condition and it's all gotta go! Prices include shipping.
  • SOLD Kooks 1 7/8" Long Tube Headers with Jet Hot 1700 degree extreme sterling silver ceramic coating and Kooks High Flow Cats (both pipes have an extra bung for wideband O2 sensors)
  • SOLDPLX SM-AFR Wideband Air/Fuel Ratio Module with Bosch LSU 4.2 Wideband O2 Sensor
  • SOLDDiablosport Trinity T1000
  • SOLDMSD Fuel Pump Voltage Booster
  • SOLD MGW Shifter with Composite Race Knob
FOR SALE:
- Maggie w/ 3.6" Pulley | Kooks Coated 1 7/8" LT Headers | Rotofab CAI | MSD FPVB | ZR1 Twin Disc Clutch / LPE flywheel | MGW Short Throw Shifter | Diablosport Trinity / PLX boost & AFR sensor modules | TCI line-lock
mwt18 is offline   Reply With Quote
Old 06-26-2013, 05:52 PM   #2
DHSS
DHSS's Avatar
Drives: Empty
Can you pm me info about extra bung hole? I have cash in hand for headers w/cats and MGW.
DHSS is offline   Reply With Quote
Old 06-26-2013, 05:52 PM   #3
DHSS
DHSS's Avatar
Drives: Empty
Ive had kooks and ARH before and never saw or had extra holes.
Old 06-26-2013, 06:04 PM   #4
mwt18
mwt18's Avatar
The extra holes are in front of the cats. They are for wide band O2 sensors, which let you monitor the air/fuel ratio. The one on the passenger side pipe would be used by a tuner on the dyno. It stays plugged otherwise. The one on the driver side would be used if you have an AFR gage. I used the PLX and DS trinity to monitor/log AFR. It can be plugged also if you're not worried about your AFR.
FOR SALE:
Old 06-26-2013, 07:47 PM   #5
mwt18
mwt18's Avatar
Update: Headers and shifter are gone. Pics of trinity have been added.
FOR SALE:
Old 06-26-2013, 07:56 PM   #6
mikeyg36
Drives: 2015 Z/28 #533
Looks good
mikeyg36 is offline   Reply With Quote
Old 06-26-2013, 11:05 PM   #7
Sugarfree135
Drives: 2011 2SS/RS
What were you able to do with the trinity besides data logging? I'm just curious if it comes with tunes for light mods like intakes and exhausts? Thanks a bunch :-)
Sugarfree135 is offline   Reply With Quote
Old 06-26-2013, 11:43 PM   #8
Sugarfree135
Drives: 2011 2SS/RS
Nm I researched lol will you take 250 shipped to Colorado?
Old 06-27-2013, 08:00 AM   #9
inferno camaro
inferno camaro's Avatar
Drives: 2010 camaro pace car, 2008 cts bl,
Will the wdeband work with hp tuner? Is it ready to just plug in and go?
Mods, 2r max cam, ls3 conv,kooks lt w/hf cats,kooks street sleeper cat back with magnaflow res x-pipe, roto fab cai, v-max TB, vigilante 3700 stall, 3.70 LPE, 442hp/392tq, Mike Norris Tune 11.71@116.24 1.63 60' m&h DR's
inferno camaro is offline   Reply With Quote
Old 06-27-2013, 11:10 AM   #10
mwt18
mwt18's Avatar
I'm pretty sure you could make it work. You'd want to make sure the hp tuner has an analog input. What is your application? The PLX will need to be wired into the car to receive power (a piggy-back fuse is included). You will also likely need to run the O2 wiring through the firewall and make sure the wiring is zip tied away from the exhaust. So, it's a little more than just plug and go, but still very straight-forward.
FOR SALE:
Old 06-27-2013, 12:55 PM   #11
BplumCrazy-SS
BplumCrazy-SS's Avatar
Drives: 416 w/TH400
I'll take PLX SM-AFR Wideband Air/Fuel Ratio Module with Bosch LSU 4.2 Wideband O2 Sensor If i can add a gauge to it PM me your paypal info
ERL 416 - 12.5 cr, TH400, Custom VVT Cam, PRC 255 heads, NW 102 TB, Aeromotive stealth fuel system, Fast 102 plumbed with a nitrous express direct port kit, BMR 15" conversion kit
BplumCrazy-SS is offline   Reply With Quote
