Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 01-16-2014, 04:27 PM   #1
jasonfichter
jasonfichter's Avatar
Drives: 2017 A10 ZL1
67 Dash in 69?
I am thinking about buying a 69 ss and i want to put a custom touchscreen in it. The dash of the 69 doesn't look like there is any room to put it where it would make sense. I do like the 69 a bit more than the previous years because of the beefier body otherwise i would buy a 68. So my question is can you bolt a 67/68 dash in a 69 or will it take some modifications?
jasonfichter is offline   Reply With Quote
Old 01-17-2014, 06:25 AM   #2
MLL67RSSS
Drives: car
The dash panel face is spot welded in place. So the short answer is no. The '67 and '68 are quite different so it would require cutting the old out and welding the new in.
'69 on top, '67 and '68 below, and an almost 67 stripped body shell.
MLL67RSSS is offline   Reply With Quote
Old 01-17-2014, 07:16 AM   #3
MLL67RSSS
Drives: car
It is possible however to bolt in just about any dash you want if you have the skill. Entails cutting out the old, temporarily mount the new dash and fab brackets to bolt it into place. Easy, no, but it is possible. There is a guy in our Camaro club (don't have pictures here) with a '69 Dynacorn Camaro 'vert with a full interior out of a mid-late '90's Firebird. Also found this example of a modern GTO dash in a '69.
http://www.pro-touring.com/threads/8...h-in-first-gen
Old 01-17-2014, 03:45 PM   #4
MLL67RSSS
Drives: car
Well since I mentioned it and I'm home now...
I'm not too good with names, and his escapes me for the moment(SORRY!!!), but his car is awesome! He was there for at least one of the C5Fests at Indy.
Old 01-17-2014, 07:08 PM   #5
GrnMchin
Not easy being Green
GrnMchin's Avatar
Drives: 67 Nova SS
As stated above your better off building a custom dash. In my current project someone had installed a modern head unit, but did a hack job. I also had to account for the angle to make the new head unit functional. Sky is the limit pending on what you want to spend.
There is room, but you will looses the ash tray.
GrnMchin is offline   Reply With Quote
Old 01-20-2014, 08:18 PM   #6
jasonfichter
ok thanks for the inspiration guys
Old 01-22-2014, 01:36 PM   #7
jwcarguy
jwcarguy's Avatar
Drives: Camaro SS
here are pics of my 68' dash mods
jwcarguy is offline   Reply With Quote
