Old 07-19-2018, 05:17 PM   #1
jeepman
Drives: 2014 zl1 coupe, red
Is there something wrong with my ZL1
I,m new to the forum and will post pictures of my car as soon as I can figure out how to do it. I purchased in January 2018 a red 2014 ZL1 manual with 9,700 miles. The car was in perfect like new condition. I'm learning how to drive the car and am getting much better and feel more confident.
Here's the problem, or it may not be a problem, or it just might be the driver. I tried my first burnout. I brought the car to 4,000 rpm's at a stand still and let the clutch out quickly and put the gas to the floor. The tires attempted to turn over and the engine took a dump. I tried it two more times with the same results. Is there something wrong with my car????? I hope the experts on here can help. Thanks Bill
jeepman is offline   Reply With Quote
Old 07-19-2018, 05:32 PM   #2
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
I never got burnouts. I just like going faaaast.
Either get a line lock, or quickly tap the TC button twice.
https://www.camaro5.com/forums/showt...hlight=burnout
JB'sZL1 is offline   Reply With Quote
Old 07-19-2018, 05:39 PM   #3
GONMAD510
Drives: 2013 ZL1 M6
You need to hold the TC button down for a couple of seconds and both lights will come on. This will turn off all of the nannies.
Fast 850cc Injectors, ATI Balancer, 8.66 Lower Pulley, 2.55 Upper Pulley, Lingenfelter CAI, Kooks LT with cat delete pipes, Noweeds Exhaust Cutouts (extremely loud under full throttle), BTR Stage 3 Cam, BTR Platinum 660 Valve Spring Kit, TR7ix Iridium Spark Plugs, Lingenfelter Solid Isolator, 160 Degree Thermostat, Larger SC Coolant Reservoir with Hose Relocation Kit, BMR 1.25" Lowering Springs, MGW Short Throw Shifter, Racing Brake 2 piece rotors front and rear, Starkweather Performance Custom Dyno Tune on 91 Octane.
691.38 RWHP
630.35 RWTQ
GONMAD510 is offline   Reply With Quote
Old 07-19-2018, 06:45 PM   #4
jeepman
Forgot to tell you I did tap the traction control buttons twice and both lights were on.
Old 07-19-2018, 07:26 PM   #5
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Try it by holding down the button for 8 seconds. That turns everything off. That should certainly create a burnout, especially if you are running cold 9700-mile g2 tires.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides-
2014 ZL1 M6 Red Hot | Tons of mods
2004 CTS-V M6 Silver | Many mods
1995 Corvette M6 Torch Red | A few more mods
1992 Camaro M5 White | A few mods
RobZL1 is offline   Reply With Quote
Old 07-19-2018, 08:30 PM   #6
HDRDTD
Tapping it twice quickly puts you in launch control.
Try either tapping once. Tapping once turns traction control off but leaves stabilitrack active.
Holding it down for 7-10 seconds turns both off.
Old 07-19-2018, 08:47 PM   #7
jeepman
Very good information. Thanks
Old 07-20-2018, 08:09 AM   #8
lbls1
lbls1's Avatar
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ
Could be traction control/or yaw control kicking in. Car sounds healthy otherwise.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic
'15 Malibu LTZ 2LZ Turbo
'14 CAMARO ZL1 Blue Ray Metallic
lbls1 is offline   Reply With Quote
Old 07-20-2018, 08:23 AM   #9
Happy_Dan
Happy_Dan
Happy_Dan's Avatar
Drives: 2012 IOM Camaro ZL1 #569
Send a message via AIM to Happy_Dan Send a message via Yahoo to Happy_Dan Send a message via Skype™ to Happy_Dan
You certainly don't need to rev to 4000 either. Maybe if you are just learning to drive it, you should leave them on and pass on the burnouts. It's one thing if you are warming the tires at the track, it's another to just burn up tires. (wait until you have to buy new ones )
Have fun, be careful.
Happy_Dan is offline   Reply With Quote
Old 07-20-2018, 08:53 AM   #10
Juiced1
Drives: 2012 2SS CAMARO 45th
Every time I get in my Camaro I spend the first 10 seconds holding that button down until both lights popped up. Also, we recommend some mods and a tune. That always helps out on the burnouts lol.
Juiced1 is offline   Reply With Quote
Old 07-20-2018, 01:46 PM   #11
jeepman
Well the information that the many gave me resulted in a small burnout. That was my first and last.
Old 07-20-2018, 03:05 PM   #12
JB'sZL1
No joy? I think you'll find plenty of enjoyment in tracking, dragging, daily driving and some spirited driving the Z.
Old 07-20-2018, 03:58 PM   #13
jeepman
As promised here are the photos of my new ZL1.
Old 07-20-2018, 04:24 PM   #14
JB'sZL1
That's exactly my car: red w/ black wheels and sunroof, sans the mods.
Sweet ride!
