07-22-2018, 09:43 AM | #1 |
USA-1
Where can I get camber bolts?
Hey guys,
I am getting my car aligned and the shop called and said they couldn't adjust the front camber since there weren't bolts there. I've read through a few threads on here and seen conflicting information. I've seen that you don't need them, then I've seen that Chevy didn't install bolts so you can't adjust it unless you buy aftermarket bolts. From what I can tell I need two M10-1.50 x 40mm, Cylindrical, Socket Head Cap Screw, Class 12.9, Steel, Zinc Plated Finish bolts, but I can only find them in packs of 50/100 online ($18 or $48), when I only need two. Does someone know where I can get these?
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
07-22-2018, 10:03 AM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
Justice Pete sells the bolts needed to fit into the threaded hole at the top of the knuckle (I'm sure most hardware places do too but I don't know of any of the top of my head), however, this bolt is not necessarily needed and is more for fine adjustments - the tech just has to loosen up both bolts holding the bottom of the strut to the knuckle to adjust camber (the bottom bolt hole is elongated).
07-22-2018, 12:03 PM | #3 |
USA-1
Sounds good! Thanks man!
