04-10-2022, 12:52 PM | #1 |
Drives: 2011 Camaro SS Join Date: Jul 2017
Which Fuel pressure regulator?
I'm swapping to a return style fuel system with a Fore triple pump hat. I'm curious which regulator are you guys with similiar systems using. I'll be going 10an to a Y block to both rails from the hat and filter and a 8an return from the regulator. Thanks.
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
04-11-2022, 07:17 AM | #2 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
04-11-2022, 09:46 AM | #3 |
Fore F2i Fuel Pressure Regulator on my twin pumps and never had a problem, with triples I'd run the F4i.
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM |
04-11-2022, 03:30 PM | #4 |
Sucker Punch
Drives: 2013 Black ZL1, 2007 Silverado LTZ Join Date: Jul 2014
Fore F2i Fuel Pressure Regulator with triple Walbro 450's pushing E85 no problems.
427 Dart SHP Pro LS Block, Callies Magnum Crank, Callies Ultra I Beam Rods, Diamond Pistons, AGP twin Turbos 6865, Mast heads, Cam Motion LLR cam, Morel tie bar lifters, Crower roller rockers, NW 103MM TB, ID2600 XDS, Fore Triple, DSX, E85, ARH Turbo Headers, Corsa, Jakes stage 5 4L80, Circle D, RPM Roll Bar, BMR, Carlyle Racing 15" conversion kit.
04-12-2022, 01:53 AM | #5 |
Drives: 2009 ZR1 Join Date: May 2010
I ran a Magnafuel
Thread Tools | |
