Old 11-02-2012, 09:33 PM   #1
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
Governor Christie (NJ) issued gas restrictions.
To all who are driving around, I got gas today myself, but Northern NJ issued gas restrictions and is now enforced odd and even day restrictions for gas. I don't know exactly how it's working but it's within your best interest to look into it. I've also gone into PA to get gas. Southern NJ has no restrictions. Check it out. (Sorry to the PA folks for taking you gas).
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 11-02-2012, 10:53 PM   #2
VanquisherSS
Hasbin of Stock Bottom HP
Drives: CTS-V Coupe, 04 TT Viper
Edit: Looked it up just FYI Odd ending plates are odd days and if you have a custom plate or no numbers you fill up on odd days.
Hopefully I get my delivery from VP Racing Fuels next week.
VanquisherSS is offline   Reply With Quote
Old 11-02-2012, 10:55 PM   #3
fielderLS3
fielderLS3's Avatar
Drives: 2016 Mazda6, 2011 Mustang 5.0
Isn't it normally the other way around?
2022 1SS 1LE (Arrived 4/29/22)
"The car is the closest thing we will ever create to something that is alive."
. 2022 1SS 1LE (Coming Soon)
fielderLS3 is offline   Reply With Quote
Old 11-02-2012, 10:56 PM   #4
fielderLS3
fielderLS3's Avatar
Actually, I do have a serious question. Are there lines for diesel like there are for gas?
Old 11-02-2012, 10:57 PM   #5
VanquisherSS
Well considering you have to get into the station for the diesel yes you wait on the same line.
Old 11-02-2012, 11:00 PM   #6
fielderLS3
fielderLS3's Avatar
Aren't there some stations where the diesel pumps are on their own island away from the gas pumps?
Old 11-02-2012, 11:02 PM   #7
VanquisherSS
Yes however the gas stations have been restricting entrance into one side usually to control the flow. Things have been so hectic trying to get gas here that nobody is letting you in front of them even if your trying to go to an unrelated pump.
