#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
BeckyD @ James Martin Chevy
Old 01-15-2024, 10:27 PM   #1
RIPws6
RIPws6's Avatar
Drives: 2019 2SS Riverside Blue
CEL Question
I have a 2019 SS with 23k miles.
Have had zero issues with this car until today.
Driving back from work I noticed the CEL was showing a steady light.
The car is driving perfect. The only thing I noticed is the AFM is not working,
Not that that is a problem, lol! But it’s not normal. I plan to take it down to have the codes read, but I was just curious sitting here tonight, if anyone had any insight into what this might be.
I got out of the car and went to the rear and listened to the engine idle. It sounds as smooth as it can be. I detected no misfiring. Obviously, our cars don’t have gas cap so I know that’s not the issue.
The only thing out of the normal around here is that it is unusually cold. The temperatures the last couple of days have been in the single digits. As it is in many areas in the country right now.
Any ideas?
RIPws6 is offline   Reply With Quote
Old 01-15-2024, 10:38 PM   #2
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Drives: 2020 2SS - A10, NPP, MRC, CAI
Any ideas?
Buy yourself an OBD-II reader on Amazon, you can get ones that hook to your phone for like $25, best investment ever, at least you'll go in armed with knowledge (you can Google any codes you find that will help you understand what caused the CEL)...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires
Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph...
2SS Capt is offline   Reply With Quote
Old 01-16-2024, 12:24 AM   #3
Rogueleader_92
Drives: Chevy camaro, Chevy cruze
While we don't have a gas cap the door does still need to be closed all the way. Check that.
(Previous, totalled, hit from behind 8/2023) Black 2010 Camaro 2LT, RS. 82K miles.
Blue 2023 Camaro, 3LT, RS.
Rogueleader_92 is offline   Reply With Quote
Old 01-16-2024, 06:39 AM   #4
Number 3
Hail to the King baby!
Number 3's Avatar
If you have OnStar just push the blue button. They can read the code(s) for you.
Old 01-16-2024, 07:00 AM   #5
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
No, it doesn't. The fuel door has no sensors.
735 rwhp | 665 rwtq
Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods
JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune
1100 - 1/30/18 | 2000 - 1/31/18
3000 - 2/06/18 TPW 2/26/18
3400 - 2/19/18 | 3800 - 2/26/18
4300 - 2/27/18 | 4B00 - 3/01/18
4200 - 3/05/18 | 4800 - 3/14/18
5000 - 3/16/18 | 6000 - 3/19/18
arpad_m is offline   Reply With Quote
Old 01-16-2024, 07:11 AM   #6
ember1205
Hot Camaro
ember1205's Avatar
Drives: '20 2SS Convertible 6MT
Can't support this approach enough. Once you have the reader, you put an app on your phone. Many of these, for the purposes of reading codes, are free - inCarDoc, Torque (Lite), and TrackAddict are ones that I use.
I have a FOSEAL reader that I've used on my previous truck with TrackAddict to diagnose a high pressure fuel pump that was starting to fail and then with my wife's Acura RDX to determine which oil pressure switch had failed putting her car into limp mode. I had to search the codes, look through forums, and learn more about the inner workings of the vehicles to diagnose the issues, but I learned a lot and saved hundreds of dollars (likely much more on the Acura) on each repair. I also used the setup on my new truck to provide details to GM about issues with codes right off the lot that ensured they did the correct repairs (on the second try because they ignored me at the dealership level on the first try).
ember1205 is offline   Reply With Quote
Old 01-16-2024, 07:42 AM   #7
GXP08jrf
Drives: 2016 1LT 'Vert
There are several hundred reasons why you may get a light but notice no performance or operational issues. With a very wide variety of systems being monitored, it's impossible to narrow down likely causes from the description of your experience.
Any potential cause offered here without knowing the code is 100% pure speculation and has more potential to lead you down the wrong diagnosis path spending more time, money and aggravation.
As others have said, you need to read the code(s). OnStar will do it. I believe most chain Auto Parts stores will do it (for free), But as others suggested, for about 1/3 the price of a fill-up, you can buy a cheapo code reader for the future or a surprisingly powerful OBDII interface and phone app for some real-time information...
GXP08jrf is offline   Reply With Quote
Old 01-16-2024, 08:47 AM   #8
easttxss
easttxss's Avatar
Drives: '16 2SS M6
Maybe he meant the little flappers in the cap have to be closed so the evap system is sealed off. Not the actual fuel filler door.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB
'16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20)
'14 Fusion Titanium 2.0T
'83 Jeep Wagoneer
easttxss is offline   Reply With Quote
Old 01-16-2024, 01:02 PM   #9
arpad_m
arpad_m's Avatar
Yeah, indeed that's possible, the rubber flappies do need to close all the way (but there is nothing for the driver to do about it).
735 rwhp | 665 rwtq
Old 01-16-2024, 05:19 PM   #10
RIPws6
RIPws6's Avatar
So the code was P01F0. Coolant temp dropped below diagnostic levels.
Cleared the code…it’s gone
So the 1 degree temps caused the code.
Old 01-16-2024, 07:37 PM   #11
david_acm
david_acm's Avatar
Drives: LT1
It might be a good idea to check your coolant level to make sure the top tank is full and the bottom one is half full.
https://www.camaro6.com/forums/showthread.php?t=555908
david_acm is offline   Reply With Quote
Old 01-20-2024, 08:52 AM   #12
Hack
Hack's Avatar
Drives: 2021 Camaro LT1
It's been below zero here and no codes on my 2021. I doubt the cold temperature had anything to do with the code. Something else is probably going on.
Hack is offline   Reply With Quote
Old 01-25-2024, 11:26 AM   #13
ctrlz
Drives: 2017 2SS, 50th pkg, M6, MRC, NPP
I tend agree with Hack.
The more likely explanation is that the thermostat is not fully closing, and the car is taking longer to warm up, or never getting up to temp.
Is the car warming up normally and is the heater operating normally?
ctrlz is offline   Reply With Quote
Old 02-20-2024, 10:00 PM   #14
RIPws6
RIPws6's Avatar
Heater and everything worked fine. Code never came back so hopefully it’s a done deal until it’s 0 degrees outside again.
