Old 05-18-2018, 02:53 PM   #1
Dipped_Camaro
Dipped_Camaro's Avatar
Drives: Twin Turbo Camaro
2013 Camaro 2SS IPS Twin Turbo 851hp/968tq
Car is located in Wheeling WV
Odo reads 53212
8,500 Miles on Motor
2,500 Miles on Trans
I have all the Receipts for labor and parts
Car is Wrapped Bismark BattleShip
Its been Plasti Dipped since 15,000 Miles ( of Course Different Colors)
The car is originally black and still is black underneath
Car has been garage kept since all the mods were done. Turbos were put in by Jannetty Racing & Carlyle Racing did the motor + Trans + Flex Fuel. Roll Cage & Air Ride was put in by East Coast Fab Works. 304 Dips Did the PlastiDip and Vinyl Jobs.
- Stock parts are for sale if i still have them
-Engine
Livernois 429 ls3 block Fully Forged Rated to 1350hp (w/ Darton Sleeves)
TR7IX Spark Plugs
ZR1 3 Bar Map Sensor
Converted to an LS3 from L99
Custom JRE Cam
255 CNC Trick Flow Heads
ATI Balancer
ARP Head Studs, Crank and Sprocket Bolts
Ported Throttle body
Oil Catch Can
Vibrant Manual Boost Controller
Stock Intake Manifold
Magnaflow Comp 3” Exhaust (with Cutouts by Turbos- Currently have Plates on the Cutouts)
American Racing Headers (Ceramic Coated)
-IPS Fabberge Twin Turbo Kit (Trans Mounted)
10Lb WG Springs
Garret T3/T4 Turbos 60 Trim St3 .82 A/R
Fabberge Intercooler With Black charge pipe
Tial 60mm Bov
Skid Plate
-Transmission
6l80e Removed and Replaced with 6l90E
2 Transmission Coolers with fans
Pro Torque Triple Disc Converter
Zl1 Trans Mount + Crossmember
-Fuel
Squash Dual 450 8-6 Return
Aeromotive fuel Rails
ID1500s with Flex Fuel Sensor
Alky Meth System (Runs on it when your running 93)(Dual Nozzle)
-DriveTrain
Carbon Fiber 1pc Driveshaft DSS
1000hp axles DSS
-Suspension
BMR Bushing Kit
BMR Lower Control Arms
BMR Toe Rods and Trailing arms - Adjustable
BMR Butterfly Undercarriage Brace + Tunnel Brace
ZL1 Adjustable Sway Bar
Air Lift Performance Bags v2
- Tank + Viar Compressor
- V2 Control Management
-Interior
Custom 6 Point Roll Cage – Powder Coated Supra White - Fully Removeable
Sparco Fighter Seats - With slider Rails
Sparco 4 Point Harnesses
Rear Seat Removed – Custom Plate from Rear to Trunk
Airlift Tank and Compressor Mounted in the Trunk on the Roll Cage
-Electrical/Mechanical Addons
Carlyle Racing Line Lock
LPE Launch Control/2Step
Pillar Pod gauges
-Air/Fuel Ratio
-Boost Gauge
Oracle Halos with Controller Mounted in the Car
Oracle Foot well Mounted Lights
Oracle LED reverse Lights
-Exterior
APR Splitter with Support Rods
Havoc Rear Diffuser
Seibon CF Hood
Seibon CF Trunk
Seibon CF Fenders
Flush Hood Pins
ZL1 ACS Front Bumper with T1 Ports (Leds)
Street Scene Side Skirts
-Wheels
Vossen VVSCVT 20s – Toyo Proxies
Niche Spyder Zo6 18’s for Racing Setup – Nitto Street Radials
-Brakes
Stainless Steel Lines
Hawk Pads
Dimpled and Slotted Front and Rear Rotors
- Stock Accessories
Nav/AM/FM/XM Radio
OnStar + Bluetooth
Sunroof
Rear Backup Camera
Stock gauges by shifter (Oil Temp/Pressure Volts Trans temp)
Also have a pair of TSW Rims with brand new pirelli tires
I do have the title & nothing is owed on the car
Price is 40,000 - willing to negotiate
Have most of the stock parts if you want them with the car
Front Power Leather Seats (Heated)
Back Seats ( with All the Seat Belt Hardware)
Stock Rear Trunk with Spoiler
Stock Hood
Stock Fenders
Stock Bumper
Stock Reverse Lights
Stock Side Markers
Stock Suspension
Stock Bushings
Stock Side Skirts
Stock Rear Diffuser
Dipped_Camaro is offline   Reply With Quote
Old 05-19-2018, 07:25 AM   #2
The camaro show
The camaro show's Avatar
Drives: 2015 camaro 2lt
This car is no joke it’s a jet,I’ve it in Person and is easily the fastest car around for a while!
Cosmetic mods: SS hood with painted vent, SS bumper, acs 1le front lip black, big worm gfx tinted all lights, solar wing v2, Camaro seat belt pads and oracle color shift halos and fog light halos and rear colorshift bow tie, carbon creations carbon fiber stingray z spoiler
Wheels: lexani r-3 bg finish 19x8.5
Performance: cold air inductions intake, mrt v1, jacfab ported intake manifold, intake manifold spacer, overkill tuned on E85.
The camaro show is offline   Reply With Quote
Old 05-19-2018, 11:50 AM   #3
gm2376
gm2376's Avatar
Drives: 2010 Black 2ss Camaro SS
price?
ZL1 10 spokes,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 102mm TB, Dr Phil Tune,Borla Atak
gm2376 is offline   Reply With Quote
Old 05-20-2018, 10:33 AM   #4
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
joshnmn is offline   Reply With Quote
Old 06-06-2018, 06:50 AM   #5
Dipped_Camaro
If you want more pics or specs just ask
Old 06-06-2018, 10:12 PM   #6
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
Clearly no expense spared... beautiful ride!
RealQuick is offline   Reply With Quote
Old 06-14-2018, 08:51 PM   #7
Dipped_Camaro
thanks
Old 07-19-2018, 12:29 PM   #8
Dipped_Camaro
Still for Sale
Old 08-27-2018, 07:15 AM   #9
gen=5
gen=5's Avatar
Drives: 13 ZL1 vert blac fastlane/LPE 750
Sweet if my sale goes through before that’s sold I will check in with you..only downside I see,is the air filters..what happens when it rains,as we all know shit happens..? You ever drive it in the rain ? Guess a plate could be installed just Incase ..
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
gen=5 is offline   Reply With Quote
Old 08-29-2018, 07:30 AM   #10
Dipped_Camaro
Never had a problem in the rain, theres a 1 inch skid plate guarding the turbos and the filters have socks on them. The only problem i had in the rain was due to my street radials
Old 08-29-2018, 08:15 AM   #11
Mydivorcegift
Future Mopar Owner
Mydivorcegift's Avatar
Drives: 2011, 2SS/RS, Synergy
I highly consider this car before I ordered my Hellcat. IMHO one of the baddest cars on the forum.
I wish you good luck with the sale!
2005 GTO-IBM-A4-Sold
2011 Camaro SS/RS Synergy-1 of 255-Sold
You will be missed but you are in good hands!
2019 Challenger Hellcat
B5, Redeye, Widebody
Mydivorcegift is offline   Reply With Quote
Old 08-29-2018, 08:48 AM   #12
Dipped_Camaro
Thanks!
Old 08-29-2018, 08:58 AM   #13
The camaro show
By far one of the best camaros in the USA!
Old 08-29-2018, 09:00 AM   #14
Dipped_Camaro
Here are some more pics i have of the car & parts
