Old 10-04-2010, 12:16 PM   #1
trudawg660
Drives: 2006 Dodge Charger / 2SS IOM
Question about the GTO
I'm thinking about buying a 2004 GTO (manual) and buying a LS3 from one of the members of C5 how hard will it be to put it in? and how much would u think it will cost?
trudawg660 is offline   Reply With Quote
Old 10-04-2010, 12:27 PM   #2
T56LS102
Drives: 2013 GT Mustang A6
Not worth the $ your gonna spend, I would just look for a clean 05 / 06 with an LS2.
-Adam
T56LS102 is offline   Reply With Quote
Old 10-04-2010, 12:28 PM   #3
8cd03gro
Drives: 2005 STi corn fed
What's the point? Just to have an ls3? You could build the ls1 to make a hell of a lot more power for cheaper than it would be to swap in an ls3.
8cd03gro is offline   Reply With Quote
Old 10-04-2010, 12:52 PM   #4
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
because there is more potential out of an ls3?
because the price of an ls2 is the same as an ls3?
and the swap is pretty much straight foward. depending on what you got with the ls3 would depend on how much other stuff you would have to buy.
I would look for a gto with a blown motor first. and if you can't do the swap yourself, the cost goes up A LOT.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
danhr is offline   Reply With Quote
Old 10-04-2010, 03:23 PM   #5
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
Send a message via ICQ to 2ndgenz28 Send a message via AIM to 2ndgenz28 Send a message via Yahoo to 2ndgenz28
Nothing wrong with spending money on what you want, but id almost agree, if you wanted to spend money just to do it, id be more agreeable on putting in a built original GTO BB with a 4 speed, 20in wide tubes that do not stick out the side the stock body. [street wheelies]
2ndgenz28 is offline   Reply With Quote
Old 10-04-2010, 03:28 PM   #6
usmc8411
Drives: 2010 camaro
If you have to ask how hard an engine swap is going to be....its probably not the right job for you.
usmc8411 is offline   Reply With Quote
Old 10-04-2010, 04:02 PM   #7
Stew
Drives: 92 Luminadead/01 Dakota/97 F150 4x4
-Adam
I agree plus you get the more aggressive exterior pieces and improved brakes
Stew is offline   Reply With Quote
Old 10-04-2010, 06:23 PM   #8
SC2150
There are some awesome modded GTO's out there for far less than doing the swap you propose. If you want the performance thats the way I would go.
Old 10-04-2010, 07:07 PM   #9
Dan@showstopper
Dan@showstopper's Avatar
Drives: 2010 Camaro SS
An issue you will have is the drive by wire TB. This can be solved with a FAST 90mm cable TB. Other than that there shouldn't be much of a problem outside of the typical wiring/wiring harness associated with any swap.
Dan@showstopper is offline   Reply With Quote
Old 10-04-2010, 07:39 PM   #10
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Like most said it can be done but for the money it's cheaper and easier to just mod the 5.7l or find a newer year with the 6.0l. Of course if you're buying a car with a blow motor and getting a steal on the LS3 then things are different.
9/26/09 Took delivery!
Old 10-05-2010, 06:33 AM   #11
SK360
Drives: 2005 Pontiac GTO
You will need to swap the oil pans.
You will need to extend the Cam position sensor wiring & knock sensor wiring.
You will need the Lingenfelter trigger box to use the 58x reluctor wheel with the 24x pcm.
You will need a cable throttle body of some type.
You will need to rig the existing MAP into the bigger LS3 intake MAP hole or get a new wiring pigtail to splice in to use the LS3 MAP Sensor and make the calibration change in HPTuners for it.
SK360 is offline   Reply With Quote
Custom wheel offset question ... Bowtie Junkman Wheels and Tires Talk Sponsored by The Tire Rack 4 04-23-2010 05:16 PM
GTO or '02 Camaro nick at night General Automotive + Other Cars Discussion 29 04-06-2010 04:05 PM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 06:53 AM
Question about camaro and gto Cessna510 5th Gen Camaro SS LS LT General Discussions 36 08-19-2008 02:42 PM
GTO Godfather Jim Wangers KILLER74Z28 General Automotive + Other Cars Discussion 0 10-25-2006 03:26 PM
