03-04-2011, 11:56 AM | #1 |
Drives: 2006 Dodge Charger / 2SS IOM Join Date: Dec 2008
Rev Limiter
correct me if i'm wrong but isnt the L99 limited to 6500 rpms because of the lifters. and the Ls3 is limited at 7000rpms?
03-04-2011, 12:00 PM | #2 |
US Veteran
Drives: 2011 Silver Ice Metallic 2SS/RS A6 Join Date: Jan 2011
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS) |
03-04-2011, 12:09 PM | #3 |
1,425 hp / supercharged
Drives: (2010 2SS/L99) (1999 Corvette) Join Date: Oct 2009
The L99 rev limiter is set at 6250 rpm. The LS3 is set higher, but I'm not sure by how much.
"If it's too loud...well, you know the rest."
03-04-2011, 12:14 PM | #4 |
Drives: 2010 Camaro SS LS3 Join Date: Sep 2010
LS3 is 6700 I believe. On the dyno mine cut off at 155 mph which was before the rev limiter. I have the stock tune on my other computer to verify settings, but can't access it until this evening.
She is only memory now. |
03-04-2011, 03:18 PM | #5 |
I always thought it was 7000 rpm's for the LS3. I have the L99, but I did an LS3 conversion and the tuner didn’t change the limiter.
03-04-2011, 03:38 PM | #6 | |
I'll get a screen shot of the RPM cutoff in a couple hours.
03-04-2011, 05:39 PM | #7 |
Unless there is another setting for cutoff this is from my LS3.
03-05-2011, 12:46 AM | #8 |
50 Shades of Prey
Drives: TT/SS Join Date: Oct 2010
6700. I believe the reason for the l99 being lower is because of solid stem valves that are heavier than the hallow stem valves found in the ls3.
Futral Motorsports built and tuned
03-15-2011, 01:42 AM | #9 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
i dont think its 7k. when ted did my tune, he told me one of the things (amongst a bunch of others) that i would notice is that he raised the rev limiter to 7k (implying it was lower).
I havent gotten to 7 (6500 is the highest ive gone) since the engine is asking for the next gear right there. Just listen and feel your motor. She'll tell you as how high she wants to scream
Bone Stock |
03-15-2011, 01:55 AM | #10 |
Blowin the doors off!
Drives: A 2013 SS RS 6M SR Join Date: Apr 2010
6700 Is the limit placed on the factory ECM
2G1FS1EWXD9163847 |
Similar Threads | ||||
raise rev limiter | jnm2003 | Tuning / Diagnostics -- engine and transmission | 7 | 07-29-2010 06:55 AM |
Is there a rev limiter parameter for when the brake is depressed (2010 Camaro)? | 2010 Bumblebee | Tuning / Diagnostics -- engine and transmission | 12 | 05-07-2010 11:39 AM |
REV Limiter Stinks. | attymf | 5th Gen Camaro SS LS LT General Discussions | 79 | 03-19-2010 09:20 PM |
HELP!! Rev limiter kicked in at 4Krpm! | AlSuwaidi | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 8 | 01-28-2010 12:48 PM |
rev limiter | oldfart1941 | 5th Gen Camaro SS LS LT General Discussions | 91 | 10-21-2009 09:20 AM |
