12-04-2016, 04:39 PM | #1 |
Drives: 2016 Camaro SS Join Date: Oct 2016
EFI Tuning LLC next project
It's disappointing people are having to put off tuning for warranty purposes. Half the fun of a car like this is modding. In a couple of weeks I will begin development of a product that will help out some of you that need to stay with the stock tune but still want to take advantage of bolt-on modifications and get more out of them than the stock tune will allow. I will be protecting my IP (ie. patent) on this one so I can't divulge the specifics but it will be very slick in operation and be something representative of 2016 not 1996 in operation.
I still need to work through some details but Flex Fuel may even be possible without touching the ECM in any way. Will it be the optimized full tune implementation? No. Will there be benefits? Absolutely. This project is of a much larger scope than the AFM modules but I will be modularizing the design to get the core capability working first followed by the bells and whistles. Tim |
12-04-2016, 05:47 PM | #2 |
Drives: SS 6 speed of course Join Date: Jan 2016
way back when, we used to glass bead the resistors on the MAF to adjust the readings... I worked for Amdahl back then, made plug compatible mainframe chips. A simple MAS translator would be nice, a gain or loss vibratory circuit over three ranges.... you know EE 101 stuff.. Man do I miss the 8008 and Z80 for simple programing in assembler.
I'm thinking 80s though, a programable 3 position MHrz circuit via Android WiFI would be nice...
Forged short block, large duration sub .600 lift Cam Motion cam, 7200 RPM fuel cut, Pray Ported Heads, 3.85 pulley D1X, stage II intercooler, DSX secondary low side, DSX E85 sensor, Lingenfelter big bore 2.0 pump, ported front cats, 60608 Borla, LT4 injectors, ZL1 1LE driveshaft and Katech ported TB, ported MSD intake, BTR valvetrain, ARP studs, ProFlow valves, PS4 tires.
12-04-2016, 06:04 PM | #3 |
Current: '17 2SS Hyper Blue, A8, MRC, NPP
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
12-04-2016, 06:49 PM | #4 |
Drives: 2016 SS Garnet Red A8 Join Date: Jan 2016
nice.. tuning is just so expensive now a days.. 500 for tuner then 400 for tunes ugh.. then parts.. but it's worth it im sure
12-04-2016, 07:07 PM | #5 |
Drives: 2002 Camaro SS Join Date: Jun 2012
Subscribed!
12-04-2016, 08:32 PM | #6 | |
Tim |
12-06-2016, 02:44 PM | #7 | |
Drives: 16 2SS Join Date: Jun 2016
In regards to your patent, it doesn't matter if you tell us. You have 1 year from your publishing of information to file an application and maintain priority. Plus when you do patent it, it will become public knowledge anyway. I think you mean to say that it is currently a trade secret? Sorry I'm an IP lawyer and this gets me with inventors sometimes although don't take my statement as advice. Otherwise, really looking forward to your developments. Sent from my iPhone using Tapatalk |
12-06-2016, 02:45 PM | #8 | |
Thank you, Tim |
12-06-2016, 02:51 PM | #9 |
Piggyback ECU?
12-06-2016, 03:08 PM | #10 |
No. But it will address some real limitations when you can't tune.
Tim |
12-06-2016, 04:40 PM | #11 |
gm performace ecu....
12-06-2016, 04:45 PM | #12 |
double post
12-06-2016, 05:37 PM | #13 |
Drives: 2017 Nightfall Grey Auto 2SS Join Date: Mar 2012
12-06-2016, 06:28 PM | #14 |
