11-22-2019, 06:25 AM | #1 |
Drives: 2010 Chevy Camaro 2ss/rs TF edition Join Date: Feb 2019
Gear talk
Need some advice from the experienced people who have swapped their gears. I have a 2010 Camaro SS with the LS3 and am debating replacing the stock 3.45 gears for something else such as 3.91's or 4.10's. I am full bolt ons (headers, catback, cold air, ported TB and will be getting the GPI rod mod as well as a cam eventually). For those who have done it, what would be better for a stick car? I don't drag race, only a few roll races here and there. Want the car to get up and go a lot quicker. I've heard a lot of talk a while back about 4.10's breaking a lot, should I still be concerned with that? Anything else I should replace as well to go along with the gears? I'd appreciate links for a full kit if anyone wants to do that and would love feedback. Thanks!
11-22-2019, 06:38 AM | #2 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
Most seem to happy running 3.91s. Doubt you would break 4.10's unless they weren't set up correctly.
11-22-2019, 06:53 AM | #3 |
I heard of a lot of issues with the 4.10s back when I had my 2010 SS. I went with the GM 3.91s. They were a great price and worked great with my car that had similar mods as yours plus a mild cam.
11-22-2019, 08:41 AM | #4 |
Drives: 2010 Camaro 2SS/RS M6 Join Date: May 2009
Since you said LS3, I am assuming that you have a manual transmission. Anything less than 4.10s is leaving performance on the table. If there was an option for lower gears in our diffs, I would go even lower than 4.10s.
Depending on your budget, you might want to look at installing a Truetrac at the same time. The stock posi units have a tendency to turn into one wheel peelers when the clutches get worn out. As far as longevity, I have over 80 hits on the drag strip with my set-up and haven't broken anything in the diff yet.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings Hotchkis sub-frame brace Stop Tech Z-23 brakes 4.10 gears, Eaton Truetrac, LPW diff cover Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA |
11-22-2019, 08:53 AM | #5 | |
11-22-2019, 09:02 AM | #6 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Since you are not racing....3.91's would be my choice.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
11-22-2019, 09:22 AM | #7 | |
Drives: 2010 SS L99 Join Date: Sep 2018
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
11-22-2019, 10:29 AM | #8 |
Haven't run at the track yet. This is times based off my tuner. So take it with a grain of salt. street tires 11.55 121mph soft launch
11-22-2019, 12:32 PM | #9 |
Drives: 2014 2SS/RS Join Date: Jan 2018
my car is cammed and I went 3.91 due to a few factors. Cost was number one. After having 3.91, I think 4.10 would be fine to daily also
2014 2SS/RS LS3/M6
11-22-2019, 12:52 PM | #10 |
Drives: 2012 Camaro LS3 2SS Join Date: Oct 2018
SS vs 1LE
I too have an LS3 MN6. I have not convinced myself to go to 3.91 yet. My only concern is that I would be shifting to 2nd TOO quickly. The 1LE has 3.91s but the transmission is different, so it seems like the stock 1LE shift points would be about the same as a stock SS in gears 1-3. So if you put 3.91s in the SS your shift points 1-3 would be sooner than a 1LE, correct? Maybe I'm missing something?
Z/28 Cold Air Intake; ARH 1 7/8 Long Tube Headers, High-flow Cats, X-Pipe; Borla ATAK; 160 Deg. Thermostat; Craven Tune
11-22-2019, 12:58 PM | #11 | |
11-22-2019, 01:13 PM | #12 |
Drives: 13 IOM 2ss RS manual Join Date: Jun 2018
AGM is the OE supplier for our SS rear differential, they do not offer anything steeper than 3.91, I suspect there is a reason for that. For street driving you won't see a plug nickel from 4.1 to 3.91. I went with the AGM 3.91, installed the JRE posi kit, along with JRE billet carrier caps and an LPW girdle/cover, I have about as strong of a setup as possible for this particular differential. I don't drag race anymore, never have in a gen 5, but if I do decide to go to the track I want the best chance of driving the car home afterwards as I can give myself. Next for me is suspension bushing, toe rods, and trailing arms to guard against possible wheel hop these cars are notorious for.
Rectangular Dollars will beat Cubic Inches
11-25-2019, 04:16 PM | #13 |
Bump. Want more people to chime in
11-25-2019, 04:46 PM | #14 |
Drives: 2013 Black 2SS Join Date: Feb 2013
I have a '13 and this is my next modification on the list and it's out of necessity. Have a BTR Stage 3 cam in and the stock 3.45 bog the low end out of it. Hard to get good launches and 6th gear is useless and bogs the engine below 2k. Meaning to be able to use 6th I have to be going over 80, otherwise its knocking and pinging when you apply throttle.
Plan is Motive 4.10s / Eaton TrueTrac / LPW Cover — since my budget isn't catching up to my needs at the moment, I may have to go with just the 3.91. I hear there are quite a few 1LE rear ends available to purchase and makes the whole swap cheaper.
2013 2SS ::: MiSSy
BTR Stage 3 :: GM 3.91 :: Eaton TrueTrac :: SW LT Headers :: Elite Catch Can :: CAI :: ADM Cold Scoop :: VMAX ported TB :: Forza 3Way :: BMR Lowering Springs/Toe Rods/Lower CA/Trailing Arms/Subframe Bushings |
