Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > V8 Bolt-Ons & Tunes
Old 01-20-2015, 09:36 AM   #1
dynosteve
Dyno Tuner & Calibrator
dynosteve's Avatar
Drives: 2010 SS Camaro Turbo
Exclamation SCT X4 Free Tune & Free Shipping from RDP Store
RDP is Proud to Offer the All New SCT X4 Wireless Programmer 7416.
With This Special for Forum Members we will give a Free Custom Tune to Anyone Purchasing a SCT X4 Unit from us and we also same Day Ship for Free to your Door.
Below is a over view of the System.
Stores up to 10 custom tune files created by your local SCT Custom Tuning Dealer.
High Speed Datalogging / Monitoring
View & record your vehicles PCM data on the LCD screen or on your laptop.
Easy Restoration Back to Stock
The X4 Flash device backs up your factory PCM program during installation should you ever need to return your vehicle to the stock program. Restoring your vehicle to the stock PCM program is as easy as selecting "Return to Stock" from the device menu. With all SCT devices, once returned to stock, there is no footprint or trace of the tune in the vehicle's PCM.
Most Popular Vehicles Supported
Most popular GM vehicles supported
USB Interface Cable Included
USB Interface Cable & Livelink Datalogging software included
Built-In Wifi for easy updates
Built-in Wifi allows you to easily attach to your local area wireless
* Adjustable Options vary for each vehicle and are not available on all vehicles
Rear O2's Disabled
Disables the Rear O2s and eliminates CEL caused by rear O2 removal.
Fuel Injectors
Allows you to adjust for different sized fuel injectors.
CMCV Delete Plates
Allows you to disable the CMCV (Charge Motion Control Valve) in your vehicles PCM to prevent a Check Engine light and other issues associated with removing the CMCV plates in your vehicle.
Speed Limiter
Allows you to Remove, Increase or Decrease the vehicles speed limiter.
Idle Speed
Allows you to Increase or Decrease the vehicles idle speed.
Traction Control
Allows you to disable the vehicles Traction Control without using the button in the vehicle.
Spark Modification by RPM
Allows you to Add or Remove Timing by RPM Range. (0-2000)(2000-4000)(4000-8000)
WOT Fuel
Allows you to Add or Remove Fuel at Wide Open Throttle.
Shift Firmness Control
Allows you to change the transmissions shift pressure. Controls how firm the shifts will feel. * Vehicles with Automatic Transmissions ONLY
Axle Ratio
Allow you to set the axle ratio (gear ratio) to correct shift patterns and the speedometer on your vehicle.
Tire Size
Allows you to set the tire size to correct shift patterns and the speedometer on your vehicle.
Aftermarket Intake
Allows an aftermarket intake to be run on the vehicle without a Check Engine Light. For Intake Kits that require tuning, this will provide a selection of available intake kits.
Stores Stock Tune
Stores a true copy of your vehicle's stock file before programming. Used for warranty repairs and unlocking the programmer.
Supports Custom Tunes
Supports and holds custom tunes.
Fan Control
Lowers the Temperature at which the Fan turns on.
Idle Speed
Rev / RPM Limiter in Drive
Allows you to Remove, Increase or Decrease the vehicles Rev / RPM limiter in Drive
Rev / RPM Limiter Neutral
Allows you to Remove, Increase or Decrease the vehicles Rev / RPM limiter in Neutral
Speed Limiter
Fan Control
WOT Fuel
Axle Ratio
Tire Size
WOT Shift Points by Gear
Allows you to Increase or Decrease the Wide Open Throttle Shift points of each gear individually.
For Special Pricing with Free Shipping to your Door Pm us here or Give us a call on 440 358 5500 or 440 251 8571
RDP Store www.rdpstore.com
Shop 440 358 5500
Cell 440 251 8571
Kooks ARH Stainless Power ACT Aeroforce Kooks Husky AWE Gforce GForce SCT Edelbrock Whipple Magnuson Rotofab CAI Fore DSS Mishimoto Borla Magnaflow Corsa Trutrac EBC FIC
dynosteve is offline   Reply With Quote
Old 01-22-2015, 09:29 AM   #2
dynosteve
dynosteve's Avatar
Specials Still Running with Same Day Free Shipping to your Door
Shop 440 358 5500
Cell 440 251 8571
Old 01-22-2015, 12:31 PM   #3
i2disturbedSS
i2disturbedSS's Avatar
Drives: 2010 SS L99 IOM
So this will be a custom tune for my car with my mods? If it is not to my liking will you adjust for free? What is the cost for additional tunes if anything is added in the future?
369rwhp/392rwtq
"Spending money I don't have, to buy parts I don't need, to impress people I don't know!" -Jenkins
i2disturbedSS is offline   Reply With Quote
Old 01-23-2015, 09:57 AM   #4
dynosteve
dynosteve's Avatar
pm sent sir thankyou
Shop 440 358 5500
Cell 440 251 8571
Old 01-23-2015, 05:35 PM   #5
pdogii
JR-n-Tina
pdogii's Avatar
Drives: 2012 White/Black 2SS/RS M6
Does this mean GM can't tell the engine tune was changed?
2012 2SS/RS LS3 - Rotofab, Vitesse TC
pdogii is offline   Reply With Quote
Old 01-23-2015, 06:55 PM   #6
dynosteve
dynosteve's Avatar
According to SCT the Checksum will be returned to stock and makes it so gm cannot detect it sir so yes
Shop 440 358 5500
Cell 440 251 8571
Old 01-23-2015, 07:04 PM   #7
mar10
mar10's Avatar
Drives: 2010 SS RS
It says data logging. Does it have the ability to read display and log air fuel ratios to ensure that the tune is spot on? Also what is the pricing on this? As long as I stay on track with my bolt on purchases I will need a tune in the next couple months. If this tracks A/F then it may be a good alternative to a dyno tune for me depending on the price.
mar10 is offline   Reply With Quote
Old 01-23-2015, 09:25 PM   #8
SSlow1
Drives: 2014 Camaro SS
Who does the custom tune
SSlow1 is offline   Reply With Quote
Old 01-24-2015, 01:59 AM   #9
SSCamaro1LE
SSCamaro1LE's Avatar
Drives: 2013 Camaro 2SS/RS 1LE
I just got mine in the mail today. It doesn't display A/F which is a bummer but does display a bunch of other information.
SSCamaro1LE is offline   Reply With Quote
Old 01-24-2015, 03:22 AM   #10
dynosteve
dynosteve's Avatar
i do them myself here sir
Shop 440 358 5500
Cell 440 251 8571
Old 01-27-2015, 05:24 PM   #11
dynosteve
dynosteve's Avatar
Specials Still Running with Free Same Day Shipping
Shop 440 358 5500
Cell 440 251 8571
Old 01-27-2015, 06:27 PM   #12
The_Blur
Moderator
The_Blur's Avatar
This is a good unit and a good tune from a good vendor. Do it.
I'm speaking from experience on this.
warn 145:159 ban
Old 01-28-2015, 03:00 PM   #13
dynosteve
dynosteve's Avatar
much appreciated sir
Shop 440 358 5500
Cell 440 251 8571
Old 01-28-2015, 10:49 PM   #14
j.curt
Drives: 2017 Camaro 1SS
I have the same question as well. What makes this different than the Diablo tuner? What is the price for this?
j.curt is offline   Reply With Quote
sct x4 free rdp
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
