Old 04-18-2020, 11:51 AM   #1
2slik
Drives: 2010 Camaro 2SS/RS
Who's running aftermarket rocker arms....reviews, opinions, pros, & cons?
So, Ive got 30k+ on a complete BTR stage 3 cam swap. At the time I decided to just upgrade the stock rockers with a Summit Racing trunnion bushing kit. It was cheap and I'm always up for savin a few bucks if I can do it myself. Lately though I've been thinkin I'd like to swap out the rockers for something stronger just to ensure longevity and for piece of mind. I did a search on here for roller rocker arms and didn't find much direct info, so if any of you aftermarket roller rocker using guys would love to chime in with experiences and product recommendations it would be much appreciated. Looking for something that is a direct bolt on, will fit under the stock valve cover, and not require a pushrod length change if possible. Thanks!
2slik is offline   Reply With Quote
Old 04-18-2020, 12:01 PM   #2
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
My opinion of course but the stock the rockers are more that capable with a proper trunion upgrade. Will be interested in seeing what everyone says though. Always up for learning new things.
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 04-18-2020, 01:20 PM   #3
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
Unless there is something wrong with them or you want to go with a solid roller cam, leave them alone. Aftermarket rockers make no extra power and are probably not as good as the factory ones for the most part.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 04-18-2020, 01:28 PM   #4
2slik
I have no doubt that the stock rockers are up to the task. Was just interested in maybe picking up a few ponies from a lighter, roller tipped set. Reduce my valvetrain weight and friction. Just curious what people have had success with in that area.
Old 04-18-2020, 01:59 PM   #5
62nalide
62nalide's Avatar
Drives: 2013 SS
Originally Posted by zz430camaro View Post
Unless there is something wrong with them or you want to go with a solid roller cam, leave them alone. Aftermarket lifters make no extra power and are probably not as good as the factory ones for the most part.
We normally see 20-28HP by swapping to Johnson lifters over LS7 lifters daily. They are 100x better than the OEM LS7 lifters.
62nalide is offline   Reply With Quote
Old 04-18-2020, 02:01 PM   #6
62nalide
62nalide's Avatar
Drives: 2013 SS
You are better off with your stock rockers really. They have done pretty well, going over to aftermarket will not net you nore gain much. I'd only recommend them of you are going solid roller.
Old 04-18-2020, 02:04 PM   #7
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Well that's interesting. I was also looking at rocker options buy they were a lot of money and no guarantee on fitment and pushrod length. I just did the che trunions. I asked jannety and they had no suggestion for an aftermarket rocker arm and suggested i do the trunion upgrade.
Whipple 2.9 CAI ID1050x injectors JMS BAP JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering long tubes 2.5 cat back borla atak ZL1 pump JRE flow control module JRE scoop 1.5" lowering springs BMR trailing arms and toe links 704WHP 603WTQ
Greenhornet2 is offline   Reply With Quote
Old 04-18-2020, 03:03 PM   #8
zz430camaro
Drives: 2015 1LE
Oops, I meant to say rockers and not lifters.
Old 04-18-2020, 03:47 PM   #9
2slik
Ok so, since you brought up lifters...I had planned on swapping those when i did my head swap. Would you be talking about the Johnson #2110 or the #2110R's when your talking about the 20-28 hp gains?
Old 04-18-2020, 07:14 PM   #10
zz430camaro
Drives: 2015 1LE
The Johnson are way better than factory ones because they have tighter clearance and don't leak down like the factory ones under much higher loads from the cam and springs. The short travel are better but you need to either have adjustable rockers to set preload or precision length push-rods if you keep factor non adjustable
Old 04-18-2020, 08:11 PM   #11
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS LS3 Swapped A6
I hadn't heard that before and that certainly has me interested.
Separately I also wonder whether link bar lifters are worth it, since I'm assuming the bars add a little bit of weight. I do like the idea of not being able to spin a lifter and also being able to delete the lifter trays. For me though, I am mainly in the market for whatever is a balance of nearly bulletproof and easy to install. By ease of install, I mean not having to be a NASA scientist to figure out correct preload and pushrod length.
I had my LS3 rebuilt late last year and just went with LS7 lifters, as I didn't know when I would cam it. But now that I did the cam install last month the LS7 lifters have me a little nervous. But do I want to pull the heads just to do a proactive lifter upgrade? I would certainly be more for it if there was 20-28 HP on the table.
2010 CGM Camaro 2SS LS3 Swapped A6 - GPI SS1 .646/.637, (224/237, 112 +4) on CamMotion 8620 core, Melling HV 10296, CHE trunnions, heads milled .015, TSP longtubes (Catless), FM Outlaw axle back, Stage 2 PTB, Vararam OTR CAI, Mike Norris Gen 2 catch can + GM 1LE clean side separator, 160º stat - Megan Racing adjustable coilovers, Firestone Firehawk Indy 500s - Tuned by Ryan @ GPI
Old 04-20-2020, 08:10 AM   #12
62nalide
62nalide's Avatar
Drives: 2013 SS
The 2110 and 2110R is worth around 10-15HP on average but we have seen the biggest gains with ST 2116LSR Short travel lifters.
Old 04-20-2020, 08:12 AM   #13
62nalide
62nalide's Avatar
Drives: 2013 SS
Your stock ones with a trunnion will do you right if you staying hydraulic roller.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
