Old 02-25-2018, 05:20 PM   #1
C-redfly
C-redfly's Avatar
Drives: 2013 VR vert ZL1
My Z is shaking bad starting around 75 mhp
All of a sudden my Z developed a very bad shake at higher speeds. The whole car shakes bad. Any ideas what the problem could be?
C-redfly is offline   Reply With Quote
Old 02-25-2018, 06:22 PM   #2
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
Check the lug nuts and suspension bolts after looking for missing wheel balancing weights
Crash76 is offline   Reply With Quote
Old 02-25-2018, 06:54 PM   #3
CamaroSS1675
CamaroSS1675's Avatar
Drives: 2013 Camaro ZL1
Wheels may be out of balance. I had that issue when I had my Camaro SS. Dealer was the only one that could get the balance right. I tried several other places..road force etc.
CamaroSS1675 is offline   Reply With Quote
Old 02-25-2018, 07:30 PM   #4
C-redfly
C-redfly's Avatar
Thanks.
Old 02-25-2018, 07:32 PM   #5
C-redfly
C-redfly's Avatar
I'm going to the dealer tomorrow for the supercharger replacement because of the rattle. I'll have them check it for sure. It's just craxy to me how your cant tell on the streets but on the freeway it's scarry as hell.
Old 02-25-2018, 09:42 PM   #6
Jackass
Doing what I like to do
Jackass's Avatar
Drives: 1963 Landrover
If that issue is not coming form the wheels being out of balance , you may want to go under the car , and try to move the drive shaft back and forward , it may have lost a bolt or two and came loose , I would do that before going to the dealer , very dangerous situation
It can also be from one of the tires came delaminated , meaning that the air in the tire got into the different layers of tha tire itself , and it buildup a bubble on the exterior part of the tire ( kind of a blister ) on the part the roles on to the pavement , and that would make the car bounce up and down rally bad
I had it happen to my old Avalanche a long while back
Jackass is offline   Reply With Quote
Old 02-26-2018, 03:03 AM   #7
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
sounds like a loose or broken driveshaft bolt
check the bolts on on the trans-to-driveshaft and driveshaft-to-diff
inexpensive fix it is that.
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 02-26-2018, 10:25 PM   #8
C-redfly
C-redfly's Avatar
The dealer said a front wheels was out of balance and changing 89 dollars to balance all 4 tires. I'll see tomorrow when I pick it up if that was the problem.
Old 03-19-2018, 06:33 AM   #9
christate1
Drives: 2013 Black ZL1 Convertible 6spd
did that fix the problem. i was wondering cause mine is doing it now :(
christate1 is offline   Reply With Quote
Old 03-19-2018, 02:49 PM   #10
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
If it's in the seat or steering wheel or both its a wheel/suspension. You can eliminate the drive train by just pushing in the clutch while moving.
Typically it's a out of balance wheel from wear, lost weight, or bent rim.. Hopefully not the latter..
ZMEnow is offline   Reply With Quote
