03-20-2018, 10:19 AM | #1 |
Drives: 2017 SS Hyper Blue Join Date: Jan 2018
Tire size opinions. Pros and cons.
I have 20x10 front and 20x11 rear rims. I know a lot of people are running 285/30R20 front and 305/30R20 in the rear, but what about 305/35R30 in the rear. I know there is a bit of rubbing but you get a little more sidewall rubber which might help in being a better ride. And info, thoughts, opinions would be great. Thanks
03-20-2018, 10:37 AM | #2 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
You can, just need to relocate the harness.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
03-20-2018, 12:00 PM | #3 |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
Why? the 305/30 is within 9mm of the factory 275/35 rears but the 305/35 is 30mm too tall! You ruin your speedo programming and throw off the traction/stability/abs systems because they now have a faulty wheel speed reading. If you only want a softer ride research your tires and get a good touring tire or all season with better ride quality than summer only tires.
Research is your friend https://www.willtheyfit.com/index.ph...=11&offset2=43
MJK3888 Instagram Link
03-20-2018, 04:23 PM | #4 |
Thanks for the info that’s just what I was looking for. I was pretty much set on the 305/30 just wanted to hear what some members had to say. Thanks
03-20-2018, 04:25 PM | #5 |
"M1SS1LE"
Definitely go 305/30
