Old 05-12-2019, 12:40 PM   #1
191Le
191Le's Avatar
Drives: 2019 Camaro Zl1 1Le/ '18 M4
Connecting the radar wiring to mirror- Please advise!
Hi All
New 1le owner here. I have just received the blendmount for my uniden r3.
I’m sure I can figure it out but what color wires do I tap into. Black is ground for this vehicle -correct? and is purple the 12volt power source? Do I remove that plastic case and connect it to under there on the windshield just behind the mirror?
Maybe there is a thread on here that already advises?
Thanks in advance!
Al
191Le is offline   Reply With Quote
Old 05-12-2019, 01:55 PM   #2
Camaro__ss
Drives: 2013 L99
I had to hook into the “passenger airbag” sign. No other options for ignition power from the mirror area for 2013, other years might be different. Some people just tap the fuse box and run a wire up the pillar.
Camaro__ss is offline   Reply With Quote
Old 05-12-2019, 03:23 PM   #3
191Le
191Le's Avatar
Hey thanks for the input. Anyone else hook up a 2019 Zl1 with advice?
Thanks
Old 05-15-2019, 06:23 PM   #4
PapaKlutch
PapaKlutch's Avatar
Drives: 2015 Camaro SS/1LE
Thanks
You ought to try the 6th gen Camaro forums since this one is the older generation Camaro forum. Everything is different on your car from our cars.
https://www.camaro6.com/forums/forumdisplay.php?f=228
2015 2SS/1LE/RECARO/NPP/RS/NAV
PapaKlutch is offline   Reply With Quote
Old 05-21-2019, 02:16 PM   #5
Tabloma
Tabloma's Avatar
Drives: Red ZL1
Very easy get the Gen5diy wire loom.
2019 Torch Red ZR1
2015 RED HOT 1LE (traded in)
2018 Garnet Red ZL1-1LE (traded in)
2018 Red Hot ZL1 A10 (traded in)
2015 Z/28 Red Hot w/ GM Wickerbill (traded in)
2009 Siverado 2500HD (Tows and Plows)
2010 Cadillac CTS (Wifes driver)
2004 Corvette Z06 Commemorative Edition (Wife’s car)
2014 Subie Outback (My driver)
Cushman Minute Misers and Scooter
Cushman Minute Miser used parts abundance
ASE Certified Master Mechanic
ASE Certified Master Collision Repair Technician
Tabloma is offline   Reply With Quote
