08-26-2023, 02:01 PM | #1 |
Drives: 2014 Camaro SS Join Date: Jan 2014
2014 1SS Camaro Twin Turbo 708rwhp @9# $28k
One owner 1SS M6 car with 72k miles and factory installed options are NPP dual mode exhaust
and short throw shifter. Its a true daily driver. Get in and drive across the country. I have added all led lights and removed fender badging along with rear emblem. The car has been well kept for and daily driven so it does have rock chips, dings, and small scratch. I blacked out the front emblem and put vinyl in-between taillights. The car was also been ceramic coated too. I have also added the following. I have receipts for most. AGP TT Kit 57/61 $8400 Mickey Mouse Catch Can $359.99 BTR Stage 2 TT Cam kit (Cam, Springs/Titanium Retainers,Pushrods, Crank bolt, and gasket set) $935 Ls7 Lifters $109 ARP Head Bolts/LS9 Gasket $525 Machine Cylinder Heads $200 ID 1050x Injectors $1000 BR7EF Spark Plugs $23.98 DSX Fuel Kit w/E85 Sensor $1210 Innovative SCG-1 Boost Controller $379.99 Dual Gauge Pod $79.99 BMR Coil-Over Conversion Brackets (CCK004) $169.95 BMR Lower Control Arms, Rear, Chrome-moly, Non-Adjustable, Delrin (MTCA030) $329.95 BMR Trailing Arms, Single Adjustable, Rod Ends (TCA033) $209.95 Strange Double Adjustable Rear Shocks (S5003) $735.95 BMR Xtreme Anti-roll Kit, Rear, Hollow 1.375" (XSB004) $399.95 BMR Toe Rods, Rear, Adjustable, Rod Ends (TR004) $299.95 BMR Subframe Connectors, Bolt-on (SFC015) $379.95 BMR Drive Shaft Tunnel Brace (DTB04) $59.95 BMR Lowering Springs, Front, 1.25" Drop, 220 Spring Rate, V8 (SP078) $129.95 BMR Bushing Kit, Rear, Upper Control Arm, Delrin (BK039) $159.95 MRR 228 Wheels (20×10,20×11) $1200 Nitto 555 G2s (285,315) $ 1150 Total on parts only $18448.45 The car puts down 708rwhp @ 9#s on 93. Haven't had it dyno'd on E85. Car is located in Panama City,FL. Thanks. Last edited by SSlow1; 08-26-2023 at 04:07 PM. Reason: Pictures |
