07-19-2023, 07:20 PM | #1 |
Drives: 2011 camaro ss Join Date: Apr 2023
Ride Hieght
I just had my car aligned after doing a 15 in conversion. Since I decided to lower my ride height on the rear. Does the car need to be realigned?
07-19-2023, 08:19 PM | #2 | |
Drives: 2010 2SS/RS 1994 Z/28 Convertible Join Date: Dec 2022
I do believe you changed the geometry of the car, my answer would be yes. Of course I would rather pay for the alignment versus buying tires. |
07-19-2023, 08:43 PM | #3 |
Drives: 2010 2SS RS Join Date: Apr 2023
Agreed
07-20-2023, 04:54 AM | #4 |
Drives: 2015 Z/22 Join Date: Aug 2015
Indeed. Changing the ride height will affect camber and toe.
07-21-2023, 05:08 PM | #5 |
Yes, as stated above. When you change the ride height, either up or down, you change the wheel geometry angles and need to realign it.
10-10-2023, 02:52 AM | #6 | |
Drives: one camaro Join Date: Dec 2022
10-11-2023, 11:18 AM | #7 |
lol. That's exactly what I said above..
