02-22-2016, 01:00 PM | #1 |
Drives: 2011 Camaro SS Join Date: Sep 2013
Blowing in the wind
Salivations!
So I lost the tonue cover on my 2011 SS on the interstate. Blew off at just shy of 80mph. Luckily I was clear behind me, but a complete lack of shoulders made retrieving it out of the question. But good riddance. It looked nice, but was a pain. So now I find the top wanting to catch air and come up at highways speeds without the cover on. I'm afraid it's gonna catch enough air to pop right up, with disasterous results. Anyone have recommendations on securing it? Bungee cords maybe? I'm sure that would look horrible, but have no better idea. Tnx!
02-22-2016, 01:16 PM | #2 |
Drives: 2014 2SS/RS VERT Join Date: Mar 2015
I keep trying to wrap my head around how people are losing covers. I drive mine with the cover on up to 100+ and regularly at highway speeds (80) with no issues. FWIW I've been on the highway without the cover and had no issues. The is a bit of "flutter" in the top but Ive never worried that it will "pop out." Mechanically, I can't see that happening, but it will accelerate wear on the top material from the flutter.
2014 2SS/RS Vert.
"Today I didn't even have to use my AK, I got ta' say it was a good day" |
02-22-2016, 02:13 PM | #3 |
That was the third time it flew off. Glad you're not experiencing that problem.
I'd call it more than a flutter. The hard piece that rests on top comes fully out of the enclosure at speed. I'm concerned that if it catches enough wind it'll get pulled out. But if u don't see that as possible, I'll try not to worry. Appreciate ur response.
02-22-2016, 02:26 PM | #4 |
done speeds up to triple digits with and without the cover -- all's good.
2014 2SS/RS VERT L99 SUMMIT WHITE AIRAID CAI BORLA ATAK CAT-BACK EXHAUST ELITE ENGINEERING CATCH-CAN RANGE AFM-DELETE MODULE HUPER OPTIK 40 CHROME PEDALS PREMIUM FLOOR MATS PREMIUM CARGO MAT DEDICATED 32GB iPHONE HD[/I][/B][IMG][/IMG] |
02-22-2016, 03:26 PM | #5 | |
I'm saying its not really possible on a properly functioning and adjusted top. Something seems to be wrong with yours. I'd run it by the dealership. As for the cover, you used the bungees to attach it, right?
2014 2SS/RS Vert.
02-22-2016, 04:27 PM | #6 |
Well that's interesting. The only thing attaching the cover to enclosure is the two tabs on the cover that snug up on the enclosure.
Bought the car used... Sounds like I'm missing something?
02-22-2016, 04:41 PM | #7 |
Lifetime Philly Fan
Drives: 2015 Spring Edition 2SS M-6 Join Date: Mar 2012
I had a '12 and now have a '15 and never had issues losing the cover. Mine had the elastic stretchable attachment that went around the 2 studs on the upper back of the rear seat.......did yours have those or those crappy metal pieces for attachment?
I also have driven very fast on the highway with both vehicles and NO cover and have never had an issue with the top coming up......yes it flops around in the wind, but stays where it's supposed to. Good luck!!
2015 Green Flash, Delivered 4/10/15
CAI, NPP Exhaust, Short-throw shifter BBK LT HEADERS 1 7/8” Tune by DynoSteve via SCTx4 Tuner One of 82 GF Ragtops built in '15 out of 811 Total [/SIZE] |
02-22-2016, 04:49 PM | #8 |
Drives: 2011 camaro ss convertible Join Date: Oct 2015
I also have a 2011 vert and also bought it used, i have a bit over a year with the car and i never had the tonue cover so every time i have the top down i drive it just like that without doing anything to it, I usually drive in highway at about 80 and theres been times when i have done close to twice that speed... It does flap a little but till this day ive never had a problem or an issue with it so you have nothing to worry about
02-22-2016, 06:44 PM | #9 | |
"SHARK" Born Apr.26,2011
Drives: 2011 CGM 2LT/RS Convertible Join Date: Oct 2011
no you are not missing something. the 2011 tonneau covers had tabs to secure to posts...the newer tonneau covers from 2012 ( I think) had bungee cords to attach to the posts instead of the tabs/clips. my tonneau cover was replaced with the newer version under warranty in 2012( I think) because my original tonneau cover was delaminating and coming apart... |
02-22-2016, 06:48 PM | #10 |
Drives: 2012 2SS/RS Vert M6 Join Date: Jun 2014
check top adjustment and height. make sure it sits down where it should in the car.
I have seen some tops that sit up slightly higher than they should and my guess is that they push up or apply pressure on the covers causing them to fly off. or your snaps are worn and not securing properly. My '12 is the original plastic snaps and I have run it plenty at 80+ mph and no lift, no issues ever. Misalignment or adjustment would be my first guess. I read these threads all the time and am confused too as I have 'tried' to see if mine will come off and it wont. |
02-23-2016, 03:17 AM | #11 |
Drives: 2013 SS Supercharged Convertible Join Date: May 2013
I won't be caught in public putting on my tonneau. It is an embarrassing afterthought and I use mine only on long distance highway drives. 2011 and 12's have the older design without the bungee cords that made the tonneau prone to lift off.
02-23-2016, 08:06 AM | #12 | ||
Drives: 2011 Camaro 2LT RS Convertible Join Date: Jul 2011
Could you also please post some pics of your top in the down position and the area behind the "tulip" (the area between the retracted top and the black plastic liner) where the bolts should be located?
Summit White Black Leather 3 Pedals Build Date: 06/27/2011 Purchased: 07/30/2011 Title Received: 08/15/2011 1984 Camaro (3rd Gen.): Traded: 1987 "Meet the new boss. Same as the old boss." |
02-28-2016, 07:28 AM | #13 |
Drives: '08 Saturn Sky, '14 2LT Convertible Join Date: Jun 2014
I've never had a problem with the tonneau cover lifting on my '15, but without it the minor flutter of the top material concerns me. I've discovered a fix that I'm sure will work for you -- if you don't mind the way it looks -- just raise the back windows. That will stabilize the air flow over the rear deck and calm everything down. (At least they're behind you so you can't see them.) If nothing else, keep this in mind so that if your tonneau cover or top looks as if it's starting to get caught by the air flow and lift up you can raise the windows to stabilize it.
02-28-2016, 10:13 AM | #14 | |
Drives: 2018 Hyper Blue 1SS 1LE Join Date: Jul 2011
Sounds like its the "old" design cover without the little bungee cords to hold on
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic Car Build: http://www.camaro6.com/forums/showth...0#post10049680 |
