Old 01-12-2012, 11:02 PM   #1
Ozzie RS
Ozzie RS's Avatar
Drives: '11 Camaro RS 2LT
"Timed" Bushings
Forgive me for not knowing but I have recently seen mention of "timed" Bushings. What does "timed" bushings mean? Making sure they face the right direction? Thanks ahead of time for your info.
Ozzie RS is offline   Reply With Quote
Old 01-12-2012, 11:05 PM   #2
Transfusion
Transfusion's Avatar
Drives: 1SS Summit White
great question. I got popcorn while we wait.
Transfusion is offline   Reply With Quote
Old 01-12-2012, 11:09 PM   #3
Jay_LHD3
Jay_LHD3's Avatar
Drives: 2019 F150 RCSB Abyss FX4
Should be done if you have lowered your cars ride height with springs.
This post explains it all!! (Bushings/Bushes = same thing!)
You need more than an alignment. You need to time the bushes to the new ride height.
The factory installed rubber bushes add spring rate to your Camaro. They are pressed into the arms. They twist. They do not rotate. The twist is where the additional spring rate comes in.
All the bushes in your Camaro were set to the factory ride height. To set them to the new ride height have the alignment shop loosen the bolts in the front inner control arm, the rear inner control arm, the outer toe links and both ends of the trailing arms. Then drive the vehicle slowly around the shop parking lot and onto the alignment rack. With the weight of the car on the wheels have him tighten those bolts and complete the alignment.
Your car will ride better. Your car will handle better. You will prevent premature bush failure.
Jay_LHD3 is offline   Reply With Quote
Old 01-13-2012, 12:33 AM   #4
MRGOODWRENCH3
Drives: 2010 Camaro 2SS/RS
Timing the bushings is VERY IMPORTANT for proper ride height, alignment and ride quality.
MRGOODWRENCH3 is offline   Reply With Quote
Old 01-13-2012, 09:32 AM   #5
caverman
caverman's Avatar
Drives: '69 SS Convertible
Here you go....
http://www.camaro5.com/forums/showth...=time+bushings
Build Journal
Old 01-14-2012, 12:53 AM   #6
Ozzie RS
Ozzie RS's Avatar
Thanks Jay and Caverman. I had never heard of the "timing" until the last few days. You learn something new every day!!!
Old 01-14-2012, 09:43 AM   #7
caverman
caverman's Avatar
I've lowered at least 2 other cars before the Camaro and didn't know about timing the bushing either. Learned it from here.
And....from personal experience I can tell you that it makes a difference. When I first put my Hotchkis springs on I didn't know to do it. Then went back and had it done and I could feel it was less bouncy of a ride. Felt like a slight spring board before.
Now I have coilovers, which you would still have to time the bushings, and the ride is even better.
Build Journal
Timing Bushings when lowering (How to) BMR guy Suspension / Brakes / Chassis 94 04-17-2020 10:02 PM
2010+ Camaro Whiteline Plus Polyurethane Progressive Bushings | Front - Rear AutoAgenda Suspension / Chassis / Brakes 31 04-27-2013 11:39 PM
Put More Power To The Pavement With Pfadt Engine Mounts And Differential Bushings!!!! Apex Motorsports Transmission / Driveline 28 11-27-2010 10:46 AM
Pfadt Street/Race Rear Differential Bushings, get more power to the pavement! Apex Motorsports Transmission / Driveline 5 08-10-2010 05:49 PM
Urethane Bushings from Energy Suspension Bewenched Suspension / Chassis / Brakes 1 04-30-2010 05:12 AM
