Old 07-30-2012, 09:08 PM   #1
bigwayne3000
Drives: 2011 Camaro LS
'11 LS lowering question
Looking to lower my '11 LS with stock tires. I would like to go with a staggered look so I am wondering who sells the best springs for this? I looked at BMR but they only sell 1.2" drop springs but like I said, I want to go for a staggered look. Also, I may be upgrading my wheels in the future but won't ever go over 20" so not sure if that should be a factor as well. Help is appreciated, thanks!
bigwayne3000 is offline   Reply With Quote
Old 07-31-2012, 05:13 PM   #2
bigwayne3000
Bump!
Old 08-01-2012, 10:32 AM   #3
bigwayne3000
Anyone, anyone at all?
Old 08-01-2012, 11:19 AM   #4
CPT_Hoolie
CPT_Hoolie's Avatar
Drives: 2012 1LT RS
It sounds as though adjustable coilovers is what you want. They should give you the flexibility to set the ride height you want and adjust it later if you put bigger wheels on.
Pedders, Pfadt, BC Racing, I'm sure there are others available.
2012 1LT RS SW
15MAR12 purchased
22MAR12 Custom stripe install
25APR12 Installed CAI intake / ADM scoop / Roto-Fab windshield washer relocation
02MAY12 Installed RX Catch Can
...MORE TO FOLLOW
"Life's full of ironies, if you're stupid." -- P.J. O'Rourke
CPT_Hoolie is offline   Reply With Quote
Old 08-01-2012, 11:21 AM   #5
bigwayne3000
I have been thinking of coilovers, I just don't have the money. I was hoping to be able to just use springs but I don't know.
Old 08-01-2012, 01:37 PM   #6
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
I believe that companies offer split drop springs for the V8. You could buy some V8 take off struts for about $90, put the springs in them and replace your entire strut/spring assembly. Should be a direct replacement for 2011's. Just throwing that idea out there.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 08-01-2012, 02:48 PM   #7
slicktempo
slicktempo's Avatar
Drives: 2011 Camaro
Pfadt springs or coilovers.
Stanced setup meaning rake?
slicktempo is offline   Reply With Quote
Old 08-03-2012, 12:39 PM   #8
TheSuspensionSource
TheSuspensionSource's Avatar
Drives: Too many to list!
Send a message via MSN to TheSuspensionSource
When running a staggers offset it will be best to run coilovers as already suggested. I have a staggered offset on my daily and the way I could make the car level was coilovers. Heres a thread link to KW V3s.
http://www.camaro5.com/forums/showthread.php?t=241523
TheSuspensionSource is offline   Reply With Quote
Old 08-03-2012, 12:45 PM   #9
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Or you can buy the pedders 1.3"/1" split drop. It gives the car a slight raked look. They also have a 1.3" / 1.5" drop.
Old 08-03-2012, 12:54 PM   #10
ModBargains.com
ModBargains.com's Avatar
Drives: Widebody 2013 Mustang GT
Location: 1721 E. Lambert Rd. Unit C, La Habra, Ca 90631
+1 Great choice there!
ModBargains.com is offline   Reply With Quote
