#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > V8 LT1 Engine, Exhaust, and Bolt-Ons
Old 08-09-2018, 09:50 AM   #1
Matt@Tick
Matt@Tick's Avatar
Drives: All GM Performance
MSD manifold and 95mm Dyno Results
This is or results from baseline vs MSD manifold and 95mm TB combo upgrade only. Stock airbox, stock exhaust. As you can see the car picked up 26 peak hp and 39-41 hp at the top of the run. This is an M6 car for those that will ask. Also still on gasoline.
http://www.tickperformance.com/2018-...dy-combo-deal/
Matt@Tick is offline   Reply With Quote
Old 08-09-2018, 11:58 AM   #2
JaxChris
Drives: '16 2SS GD1 MX0 NPP F55 IO6
Tuned prior to baseline run? Only asking because a number of similar posts tend to forget to quantify tune based gains separately of the product being highlighted, which would provide the most accurate picture for someone to compare options side-by-side.
Thanks for the data
JaxChris is offline   Reply With Quote
Old 08-09-2018, 12:44 PM   #3
Matt@Tick
Matt@Tick's Avatar
Thanks for the data
No tune. We messed with it a bit when it was stock to pry some power out of it and it never made more than the baseline. The pull with the manifold and TB were on an untouched tune as well.
Old 08-09-2018, 07:33 PM   #4
oldman
Drives: SS 6 speed of course
holly batmobile…. I always thought my MSD with 103 Katech TB ran strong (butt dyno) on my M6 and back then I tuned it myself aka mainly disable the rear 02s... LOL
Forged short block, large duration sub .600 lift Cam Motion cam, 7200 RPM fuel cut, Pray Ported Heads, 3.85 pulley D1X, stage II intercooler, DSX secondary low side, DSX E85 sensor, Lingenfelter big bore 2.0 pump, ported front cats, 60608 Borla, LT4 injectors, ZL1 1LE driveshaft and Katech ported TB, ported MSD intake, BTR valvetrain, ARP studs, ProFlow valves, PS4 tires.
oldman is offline   Reply With Quote
Old 08-09-2018, 07:38 PM   #5
glenB
Drives: Chevrolet Camaro SS
Interesting because many other MSD intakes have shown gains from about 4500 and up while losing to the stock manifold below.
I'm guessing you didn't do a run with the MSD and stock TB
glenB is offline   Reply With Quote
Old 08-10-2018, 07:53 AM   #6
Matt@Tick
Matt@Tick's Avatar
Sure did. Here is that dyno graph.
Old 08-10-2018, 07:57 AM   #7
Matt@Tick
Matt@Tick's Avatar
We have made about 90 dyno pulls with this car just trying and testing things. Cold air intakes, manifold, TB, headers, Mufflers, Timing, AFR, etc... We have really been trying to find out the best parts you can put on these things.
Old 08-10-2018, 07:59 AM   #8
glenB
Thx
Old 08-10-2018, 09:02 AM   #9
ULTRAZLS1
ULTRAZLS1's Avatar
Drives: 14 Silverado LTZ Z71, 16 Camaro SS
Will the ported 95 require any tuning or additional install procedures other than booting up to work properly? Car already has msd and ported stock tb. Tuned
And from my understanding will work with the rotofab tube with a bit of a stretch?
ULTRAZLS1 is offline   Reply With Quote
Old 08-10-2018, 10:04 AM   #10
Matt@Tick
Matt@Tick's Avatar
There may be some values that need to be changed when using a ported one. The dyno numbers you see in the first post are an unported 95mm TB. We changed nothing in the tune for it. We bolted it on and went with it.
Old 08-21-2018, 12:44 PM   #11
Matt@Tick
Matt@Tick's Avatar
[QUOTE=And from my understanding will work with the rotofab tube with a bit of a stretch?[/QUOTE]
Yes, the rotofab silicone connection will stretch over the 95mm. So you don't need any other parts to make it fit.
Old 08-21-2018, 01:39 PM   #12
Redlinez
Shifts under load
Redlinez's Avatar
Drives: 2020 Camaro 1SS 1LE rally green
Impressive. Love that effort you guys put in, nice to see real work going into these cars from several forum folks. I would think you have a nice package with real world gains to offer now. What headers are you liking on M6 cars with bolt ons and/or a cam? Did you try tuning the car after those MSD/95MM TB numbers just to see?
24 Audi S3 prem plus, sport package
HPDE - southeast - JTI- solo, PCA- blue.
22 Suzuki GSX-S 1000GT blue
Redlinez is offline   Reply With Quote
Old 08-21-2018, 02:22 PM   #13
Matt@Tick
Matt@Tick's Avatar
I like Kooks and Hooker headers. I have Hooker on my personal car.
We did make some small changes after the manifold and tb install, but again never made more than the first pull. We did the headers right after the manifold and it did require some tuning to get power out of them. But no cats and adding headers will cause that lol.
Old 08-21-2018, 03:56 PM   #14
asthmamax11
asthmamax11's Avatar
Drives: 1SS Summit White 6 speed
Was first pull on stock setup done after car was heatsoaked like most companies do when posting before/after gains ?
16 1SS M6 White
Magnuson 2.3 Heartbeat
Roto Fab
Solo Performance Cat deletes and Axleback
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
Flow one 19" wheels wrapped in Mickey Thompsons
02 Z28 M6 35th anniversary
80k miles
T-tops
Leather
Bolt ons
Joy to drive this classic every day!
Daily Driver
asthmamax11 is offline   Reply With Quote
