Old 02-06-2014, 12:02 PM   #1
Cincy10SSRS
Cincy10SSRS's Avatar
Drives: 2010 2SS RS M6
NGK TR6 plugs
I recall reading somewhere that with the LS3 (maybe other engines too) replacing the stock plugs with NGK TR6 plugs was a good thing. Any thoughts on this? Also, if so, what gap?
Traded-in car: K&N Typhoon intake, JBA Shorty headers, Solo mid-pipes/hi-flow cats, GMPP Track Pack axle-back, Vmax ported TB, Billet Custom catch can, billet tensioner pulley, Hines Hex Vents, Z/TA rear spoiler, ProCustom headlight covers, Drake black/riveted quarter window covers, GM satin fuel door, chrome and brushed caps/covers under the hood, EmblemPros underhood bowtie & fuel rail "Camaro" plates, chrome "SS" door kick-panels, chrome trunk latch plate & strut rods, Street Scene lower grille ducts w/LED lights, front bowtie-delete, Yates Performance pedals, 35% tint, etc.
Cincy10SSRS is offline   Reply With Quote
Old 02-06-2014, 02:25 PM   #2
2012LS3VERT
Drives: 2012 2SSRS Vert, Black w/M6
The TR6 is a colder plug, you don't want to do that unless you have to. Also, they are just a cheap copper core plug, they won't last long. The iridium version of the TR6 is ok, but too cold unless you are running a decent amount of boost. The stock ACDelcos are a good plug. If you prefer NGKs, the TR5 heat range plug is about stock, but get the iridium version of that also, not the copper (NGK 7243/TR5-1IX).
2012LS3VERT is offline   Reply With Quote
Old 02-06-2014, 02:54 PM   #3
sutherlacd27
Drives: 2010 Camaro SS
There is nothing wrong with running a copper plug. Just have to change them out more frequently....good excuse to get under the hood.
sutherlacd27 is offline   Reply With Quote
Old 02-06-2014, 03:01 PM   #4
Bo White
Bo White's Avatar
I put autolite coppers in my old LS3.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 02-06-2014, 03:02 PM   #5
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Its a good plug for a cammed setup or lower boost levels. No nitrous use. For what its worth the LS7 comes with a #6 heat range plug stock, same as the zr1
Rhino79 is offline   Reply With Quote
Old 02-06-2014, 03:50 PM   #6
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
Yes I am running the ls9 myself, a step colder then stock. They make a difference.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 02-06-2014, 05:46 PM   #7
Anthony @ LG Motorsports
Drives: 1994 1LE / 2006 Z51 Corvette
It isn't quite a full heat range colder...maybe 1/2 step but close.
I see zero issues with a copper plug in the cars other than having to change them every 15-20k miles. Honestly there isn't much better conductor of electricity than copper.
Sometimes a colder plug will allow you to run a little more timing, sometimes help prevent detonation when under a heavy load like towing or racing. For a daily driver...it isn't something you have to do...nor is it going to make 100000 more HP by changing the plugs.
Anthony @ LG Motorsports is offline   Reply With Quote
Old 02-06-2014, 06:33 PM   #8
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
I'm running the NGK TR55 with my cam/bolt-on setup. So they are just a little colder than stock. I changed them out at 15000 - just because. They looked great and could have run longer. But a set of 8 only cost $24 so why not.
On a stock motor I don't think a plug one range colder is bad necessarily but I also don't see much advantage either.
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears
476 rwhp/440 rwtq (sold)
SSDan is offline   Reply With Quote
Old 02-06-2014, 06:36 PM   #9
skar
skar's Avatar
Drives: 2010 2SSRS headers/CAI/tune/corsa,
NGK TR6 plugs
That's what Livernois put in mine with only headers intake and tune.
So how many miles should you go between changes?
Stainless works headers/cats Roto fab CAI /
Corsa install and tune Livernois
TSW Nuburgring 9 &10" x 20 on Invos (315 & 275 )
JL Audio XD400/4 amp
Pfadt trailing arms & tie rods sway bars.
pedders street 1 package. ,Hurst short throw shifter
With bronze bushings .
skar is offline   Reply With Quote
Old 02-06-2014, 08:42 PM   #10
2012LS3VERT
Oh, nothing wrong with a copper plug, I have them in my 99 Sierra with the 6.0L, but I have no problem changing them every 15k miles. In the cars though, I guess I am spoiled by not having to change them nearly as often since the platinum/iridium plugs have proven themselves. It is a lot easier to change them in my truck than in a Corvette, which I spend most of my time working on locally. However, the common misconception is that a tr55 is a little colder than stock. They are the same heat range as a TR5, the out of the box gap is larger. NGK created them for when GM spec'd a larger gap for the earlier LS1 motors, I think around .060 gap. GM actually changed the spec to the .040 gap that the tr5s and tr6s come out of the box with(+ or -, always gap them yourself).
NGKs tech literature say that for every 100 hp you modify over stock, to go one heat range colder. I personally just run the hotter plug, unless reading the plug indicates that I need a colder one (I.e. porcelain cracking). Less risk of fouling out, especially without a catch can.
Old 02-06-2014, 08:55 PM   #11
2012LS3VERT
Originally Posted by skar View Post
NGK TR6 plugs
Read them at around 15k. They may go longer, but they are cheap, so you might as well change them. Or change to the iridium version of the TR6s, and you will need to change them less. I would stick with that range, they may have advanced the timing enough that it might knock with a stock heat range.
And, FWIW, I'm an NGK fan over delcos. I'll have TR6IX (iridium TR6) plugs in mine next week to go with the Maggie.
Old 02-07-2014, 07:49 AM   #12
skar
skar's Avatar
[QUOTE=2012LS3VERT;7401352]Read them at around 15k.
Thanks
Old 05-24-2016, 12:27 PM   #13
CrudeJewelSS
Build,Race,Break,Repeat
CrudeJewelSS's Avatar
Drives: 2010 Red Jewel Camaro 2SS 6M
I was told to gap mine to .030 (tr6)
30 thou. Sound correct?
CrudeJewelSS is offline   Reply With Quote
Old 05-24-2016, 12:41 PM   #14
2012LS3VERT
Depends on boost level. At 6-8 psi, i gap to .035, 10-12 I gap to .030". For an N/A car, I generally gap to .038".
