01-08-2020, 07:53 PM | #29 |
Drives: 2014 Camaro SS 1LE Join Date: Jul 2019
Just finished with a compression test.. All cylinders were quick to build compression and are within 10% of each other. I honestly have no idea what it could be anymore.
Compression test results: Cylinder 1- 168 Cylinder 2- 172 Cylinder 3- 164 Cylinder 4- 176 Cylinder 5- 164 Cylinder 6- 166 Cylinder 7- 166 Cylinder 8- 163 |
01-08-2020, 09:51 PM | #30 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
i still say you need to do a smoke test.
could be leaking from the brake booster port could be leakinf from MAP sensor port ........... could be leaking from the pcv port on the valve cover.... ....etc. I still think you have a vacuum leak since you said that adding fuel didnt change anything
Bone Stock |
01-08-2020, 09:58 PM | #31 | |
01-08-2020, 10:12 PM | #32 | |
a vacuum leak at the brake booster port or at the MAP sensor port will cause a lean condition on both banks. a bad brake booster will cause it too smoke it!
Bone Stock |
01-08-2020, 10:13 PM | #33 |
Just bought a smoke machine after my last post. I’ll report back on Saturday after it is delivered.
01-08-2020, 10:23 PM | #34 |
Bone Stock |
01-09-2020, 02:29 PM | #35 | |
01-09-2020, 06:56 PM | #36 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Could be an injector o-ring. I know you went over the exhaust already, but I had to weld a 3 bolt flange onto my tsp headers to get them to seal up tight.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
01-09-2020, 07:06 PM | #37 |
Already replaced the injectors. I also removed the connection pipe entirely and welded in a pipe. I’ve checked and double checked the exhaust for leaks by pressurizing it with a few psi of air and listening, spraying soapy water, and looking for leaks. Used the same method for finding the leak the first time and it was very effective. I’ll probably smoke the exhaust just to double check when my smoke machine is delivered this weekend.
01-09-2020, 07:21 PM | #38 |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
I'm having the same issue.
Cylinder imbalance codes both banks. Lean codes both banks. Already did new O2's... Going to try and weld in some Vbands at the header collectors and mid pipes to see if that solves it.
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
01-10-2020, 04:46 PM | #39 |
Banned
Drives: cheby Camaro Join Date: Aug 2019
Exhaust temps are very important to diagnosing this. 4 cylinders are feeding the O2 sensor so all 4 get the same change in LTFT. But usually only 1 cylinder needs it, checking the exhaust temps should tell you what cylinder is causing the problem.
01-10-2020, 06:52 PM | #40 |
Smoke machine got delivered early so I spent the last hour smoking it. Plugged the intake with a PVC cap and tried 3 different access points. I found a very micro leak under the intake to filter clamp. Tightened it up and solved that one. No other leaks found.
Also tried smoking the exhaust and didn’t see anything. I then pressurized the exhaust with a few psi of air and soaked the whole thing from headers back in soapy water to check for any leaks... Nothing. I’ve tried that but with having header wrap I was having a hard time getting consistent readings with my IR heat gun. I’ll give it another shot though. |
01-17-2020, 06:08 AM | #41 |
01-17-2020, 08:21 PM | #42 |
LSx FTW!!!
Keep us posted.
This issue is driving me crazy on my junk, too. I have my widebands reading Lambda and mine likes to swing as high as 1.10 lambda just like yours.
