Old 06-03-2009, 01:32 PM   #1
quanine10
1SS/RS blk on blk 6spd
Drives: 2010 Camaro Blk/Blk SS/RS 6spd
Do you have to replace valve stem if they are removed for powdercoating?
Guy that is powdercoating my wheels told me I need to get another set of valve stems bc you cannot reuse them if they are taking off. Can someone please shed some light on my situation!
quanine10 is offline   Reply With Quote
Old 06-03-2009, 02:24 PM   #2
Nexus6
More human than human
Nexus6's Avatar
Drives: 2010 IOM 2SS/RS
Call a tire store , they will know
1100 - 10/22/2008
3000 - 05/27/2009
3300 - 06/06/2009
3800 - 06/29/2009
4B00 - 06/29/2009
Warehouse 13 survivor
Blood stains,speed kills,fast cars,cheap thrills,rich women,fine wine,i lost my sense i lost control i lost my
mind.
Nexus6 is offline   Reply With Quote
Old 06-03-2009, 02:53 PM   #3
COR Forged
COR Forged's Avatar
Drives: SS
Send a message via AIM to COR Forged
if the stems are not removable in the sense of tpms sensors then yes you will have to purchase new ones. They shouldn't run you anymore then $5 bucks each. If they are tpms then dude is trying to play you for stupid............... no offense of course just giving you the heads up
COR Forged is offline   Reply With Quote
Old 06-03-2009, 03:50 PM   #4
quanine10
it's not the tpms, it's just the rubber stems and called my dealership and they are trying to charge me 12 bucks a stem. WTF?
Old 06-03-2009, 03:51 PM   #5
COR Forged
COR Forged's Avatar
Drives: SS
dude at the dealer everything is expensive. Go to a local rim shop, they should have some black cheap ones for like 5 bucks.
Old 06-05-2009, 09:42 PM   #6
redjewel
Drives: 2010 Camaro 2SS RJT
You can't just go buy some cheap black ones. The TPMS sensor is screwed to the bottom of that black valve you currently see and it is not a regular valve stem. Yes any reputable tire shop should have them in stock as they should be changed just like a regular valve each time you change tires. You should expect anywhere from 8-12 bucks each. Your getting them powder coated whats another 10 bucks?
redjewel is offline   Reply With Quote
Old 06-05-2009, 09:56 PM   #7
Andro
NOICE!!! ™
Andro's Avatar
Drives: Force Fed 427
Are they 20" oem wheels? I thought they all had TPMS in them. If they do the wheel shop should be able to just re-use them after the rims are powdercoated
Old 06-05-2009, 10:04 PM   #8
redjewel
Not correct. The vavle stem which is rubber needs to be removed to powder coat the wheels. You CAN NOT reuse a rubber valve stem. You will need to buy new rubber valve stems that can accept the TPMS sensor. The rubber valve stems that are TPMS type valves are different from regular valve stems.
If you want to see what I am talking about go here.
http://www.mohawkrubber.com/tpms/ima...n_Bulletin.pdf
That is what our Camaro has in it. GM has been using this for a couple years now.
Hope this helps.
Old 06-05-2009, 10:23 PM   #9
2SSJIM
2SSJIM's Avatar
Drives: 2012 CRT ZL1 #1400
Hope this helps.
100% correct and very good supporting info!
2SSJIM is offline   Reply With Quote
L99 Delete Whats involved? jsharp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 59 05-26-2009 10:54 PM
L99 AFM -- It's REALLY a tough choice, for some. Step Inside. 2KZ28_For_Now 5th Gen Camaro SS LS LT General Discussions 128 04-03-2009 04:03 PM
