JUICEDMOTORSPORTS
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Road Course/Track and Autocross
Old 11-13-2017, 07:52 PM   #1
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
Please help with a decision on wheels
I am wanting to get a track set of wheels I am about to push the button on some mono block forged 19" x10 fronts 23 offset and 19" 11 by 43 offset
pretty sure they will work and with the smaller diameter shouldn't have interference with my fenders... thoughts , warnings etc your input is greatly appreciated!
JPSS Blackmagic 32mm rear swaybar caster locks and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body Cold Air Inductions c.a.i.MightyMouse Catch can Solo High Flow cats JBA silver shorty headers, npp short throw shift and lifetime xm3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings Verona XO wheels/ccs sp16a track set, mild to wild, acs ground effects
Bretts is offline   Reply With Quote
Old 11-13-2017, 09:02 PM   #2
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
cooled off for now great set just might not be best route ie not rotate-able
side note this site is not very lively anymore lol guessing gen 6 site has stole lots from here 5th post no replys
Old 11-13-2017, 09:09 PM   #3
chuckie669
chuckie669's Avatar
Drives: 2011 ss
You barely gave an hour and talk about site not being lively. I see at least 25 reads sofar. Not sure anyone on has your answer yet. Track wheels I'm assuming you mean auto x and not drag. I wouldn't think of a dedicated track wheel and rotating being used in the same sentence unless you wanted 315 on all 4 corners.
chuckie669 is offline   Reply With Quote
Old 11-13-2017, 09:15 PM   #4
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
My bad for some reason my past threads didn't notify me like they used to?
yes i don't know to much that's why i had to back away new product made in USA 6061 forged set seems to good to be true at 3100.00
Old 11-13-2017, 09:17 PM   #5
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
but an opposite sex post on wheels was up to 15 replies already
Old 11-13-2017, 09:32 PM   #6
BruHop
BruHop's Avatar
Drives: 2014 2SS 1LE,RS,NPP,Recaros in SW
Your offsets IIRC are exactly the same as a 1LE with the same wheel width (just 19's vs. 20's). You will not have any rubbing problem.
BruHop is offline   Reply With Quote
Old 11-13-2017, 09:53 PM   #7
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
Thanks Bruhop I appreciate it even if it was a 20 offset in the front should be fine I am thinking as it would just push it out a hair . Now to figure out a good tire size probably need to measure how low stuff underneath is first
Found this site was a good one
https://www.wheel-size.com/size/chev.../#trim-62-usdm
Old 11-13-2017, 09:54 PM   #8
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
This set was ordered for a 17 1LE originally so wife could always use them lol
my concern now is if my Ridetech level 2 coil overs are offering the same strut clearance as the 1LE has it looks tight...
Old 11-14-2017, 07:28 AM   #9
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 10 Legacy 2.5GT, ...
At 19" there will be slightly less strut clearance than at 20" in the same width/offset/backspacing due to strut inclination in front view. Guessing about 3mm 'tighter'. Before I suggest any minimum tire and wheel to strut clearances, how much do you trust your ability to measure those clearances and how set are you on using specific tire makes/models/sizes?
As long as the tires you get are either non-directional or have a specific "outside", you can at least swap tires side to side on the same axle. Road courses always have 360° more turns in one direction than in the other, so tire wear is apt to be a little different side to side.
Off-topic probably does get a bit busier later into the evening, technical sections less so. At 10 PM I want to forget I even have a computer. If I'm even still awake.
Norm
'08 GT coupe 5M, wheels, tires, pads, fluid, a few suspension mods . . . still almost at stock height
'10 LGT 6M (hers) and an '01 Maxima 5M (spare)
Norm Peterson is offline   Reply With Quote
Old 11-14-2017, 07:58 AM   #10
SVThis
SVThis's Avatar
Drives: 2013 1LE 1SS Victory Red 1 of 76
No reason these shouldn't fit. I ran that set up on my car then switched over to 19x11 square
2013 1SS 1LE Victory Red. 187 CAM-C
SVThis is offline   Reply With Quote
Old 11-14-2017, 08:23 AM   #11
jrhagen
Banned
Drives: Camaro
I saw your post last night, I don't track my car, only straight line racing. So I have 17s and can't help you.
But I will comment now just to up my post count.
Hope this was helpful.
jrhagen is offline   Reply With Quote
Old 11-14-2017, 08:47 AM   #12
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
good call Norm thanks never thought about the 19 having a different contact point possibly could use a small spacer here to clear or reduce the -2.4 front camber
re 71's in the 305x 4 is my goal if I can
Old 11-14-2017, 08:56 AM   #13
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
thanks for showing up guys haha ! winters coming so I shall be posting more also! the things I do to try and be faster than the wife chapter 1...
Old 11-14-2017, 04:33 PM   #14
gringo
gringo's Avatar
Drives: Camaro
Can always go back to the V8 vs V6 thread and get a few more posts under your belt there.
gringo is offline   Reply With Quote
