05-22-2014, 04:24 PM | #1 |
Drives: 2010 Camaro 2SS RS Join Date: Nov 2011
Rear view camera LCD mirror PnP harness!
05-28-2014, 12:45 PM | #2 |
does the mylink come with back up camera?
05-28-2014, 02:05 PM | #3 |
05-28-2014, 11:03 PM | #4 |
Ryddler
Drives: 2010 RS Join Date: Jan 2014
pm sent
06-05-2014, 05:03 PM | #5 |
Drives: 2011 CGM Camaro LS A6 Join Date: Jan 2011
How hard is the install on this
06-05-2014, 05:09 PM | #6 |
Really easy... one screw to release the mirror, and it slides right off... The harness is all plug and play... The hardest part (and its not even hard) is running the wires from your camera... depends how neat of a job you want to do. You can run the wires without removing anything inside the car and just stick them behind the trunk lining and under the interior panels if you want and you wont see them.. If youre anal like me and want to run them zip tied to other wires, you just have to remove the trunk lining on one side, and a few trim pieces in the interior to run them along the side of the car |
06-05-2014, 07:47 PM | #7 |
I'd need to buy a backup camera for this as well right?
06-05-2014, 08:04 PM | #8 |
Yep, any one on ebay would work. They're as cheap as $9
http://www.ebay.com/itm/Mini-Anti-fo...item2a3c83cba5 I believe this is the same camera I have on my camaro and g8, just with a different mounting point.. I have one that mounts behind the license plate and hooks over the top of it so all you see is the camera itself |
07-02-2014, 01:07 PM | #9 |
FOUR T 5
Drives: 2012 Camaro 45th Join Date: Feb 2012
Shipping quote to 96708?
07-13-2014, 07:56 PM | #10 |
how does the camera know when to come on? i.e. how does it know you are backing up? I ordered the kit from Gen5DIY, but I think I'm missing some harness parts.
2010 SS/RS born Sep, 2010, custom graphics, Whipple 2.9L blower @9.5psi, complete stainless steel E85 compatiable fuel system (FIC 1000 cc injectors, FORE fuel pressure regulator, twin GSS 420 fuel pumps & 5/8" SS fuel lines), 1-7/8 Kook long tube headers, Corsa Catback exhaust, CAI, Spec Stage 3+ racing clutch, A-pillar pod w/AEM wideband and boost gauges , and a custom HP Tune running on E85 fuel--> 682 RWHP and 587 ft-lbs torque!
07-18-2014, 12:58 PM | #11 |
the signal comes from the mirror harness... dont have to wire a + to the reverse lights or anything
08-05-2014, 11:06 AM | #12 |
Drives: '13 Avalanche & 2018 1SS/1LE SW Join Date: Sep 2010
PM'd you
2018 1SS/1LE Summit White
Cold Air Inductions CAI JLP Catch Can |
08-20-2014, 09:25 PM | #13 |
Genesis
Drives: 2010 Chevy Camaro 2SS/RS LS3 Join Date: Aug 2014
If you still have it in a week I will buy it.
10-02-2014, 10:38 AM | #14 |
Drives: 2012 Camaro 2LS 2dr Coupe Join Date: Aug 2013
Bought the mirror from this guy, came in perfect condition. Great price too. Trustworthy seller
