![]() Drives: Camaro 2012 Join Date: Sep 2019
6l50 transmission problem help help help
Hi guys i have a problem with my camaro in the automatic transmission 6speed since two months
The problem is when i put D and start driving the car, it move like 1 meter then the transmission slipping until its stops again the when try again to move it the same thing happens all over again But when i put on tiptronic i can drive it normally the only thing that happens its a small slip between the first and the second gear I change two whole transmissions including the tcm and i did a software update for all ecu's And when i scan it on computer the is no trouble code every thing is good And the problem never change Any thoughts???!!! |
![]() Drives: 2010 RS Camaro Join Date: Dec 2021
I am having the same issue - HELP
Did you figure out what this was? I am having the same issue.
Please Help! And Thank you! |
Thread Tools | |
