09-20-2022, 11:24 PM | #1 |
Drives: 2010ss M6 LS3 Join Date: Jun 2018
Confirming axles/hubs for my 2010 camaro SS please
Good day guys, I was doing late night searches, then did late night orders on Z28 axles and hubs upgrades for my 2010 camaro SS 6spd. Now I’m worried/want to confirm if I got correct parts.
2013-14 z28 axles #23473010 and 23473011 Rear wheel bearing hub 25954415 SKF (from a z28 aswell) and then nuts to match the axles 11611234 x2 washers 11611965 x2 Sound right? Thanks guys
2010 SS M6, stage 2 summit cam, CAI Intake/long tube cat delete with flow master/ZEX NOS at 150RWHP/ custom tune/MSD wires/short throw shifter/ crank vent catchcan/ SS braided brake lines/ 1.5” lower springs/bigger rear sway bar/fully poly bushings everywhere/toe arms/trail arms/front caster plates/factory shocks/steering poly inserts
09-20-2022, 11:37 PM | #2 |
Drives: 2011 Camaro 2SS/RS Join Date: Jan 2011
You got it all right! I did the same upgrades earlier this year on my 2011 Camaro. I doubled checked my parts list that I ordered for Z28 parts and they all match. Have fun!!
Allen
2011 Camaro 2SS/RS |
09-21-2022, 08:18 AM | #3 |
Drives: 2010 Camaro 2ss/rs, 2008 Avalanche Join Date: Jan 2019
Hi guys, I wanted to clarify that the Z28 axels and hubs mentioned ,will work in my 2010 ss m6 with my stock driveshaft and diff. I'm thinking of doing the same thing.
2010 Rally Yellow 2ss/rs , M6 ,416ci , K1 rods & crank,weisco -3.0cc dome pistons,.040 head gasket, 11.5 compression,1 3/4" LT ,3" pipes w/x-pipe no cats, Cam Motion cam 239/247 113+3 .621"/604" lift , BTR .660 Platinum dual springs w/Titanium retainers, CAI . Stock ls3 heads,intake,injectors & TB. 515rwhp/500rwtq.
09-21-2022, 10:35 AM | #4 |
Thanks for confirming DMA05!! Appricated!!
Pkeen: My car is same as yours. Ill confirm on this thread once i install. PS: my axles ended up being fine, was a diff posi that FAILED, installing the torque worm LSD.
09-21-2022, 12:18 PM | #5 |
Ok thx Jaysrippen !
09-21-2022, 03:35 PM | #6 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
1LE and Z28 axles as well as Z28/Zl1 hubs are all interchangeable with the 8.6 diff regardless of manual, auto, 1LE or z28. The 1LE and Z28 axles do use the ZL1 nut on the end of them though.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
09-21-2022, 09:11 PM | #7 |
Thank you sir !
Thread Tools | |
