Old 01-11-2022, 01:29 PM   #1
Samspeed
Drives: 2010 2ss
Ls9 powermax cam question
Hi everyone.
I’m in the process of an Lsa conversation on my ‘10 SS and was planning to do a cam swap and chose the ls9 powermax. Does anyone have any knowledge with this cam choice in the LS3? They recommend the pac1218 springs but the cam lift is .600” and the 1218 springs max is the same. Also would the stock Ls3 pushrod be okay to use? I also plan to use a 2.75” upper pulley and LT headers and a cai. Thanks for any help.
Samspeed is offline   Reply With Quote
Old 01-11-2022, 01:31 PM   #2
Samspeed
Drives: 2010 2ss
Sorry about the auto correct, I meant conversion.
Old 01-12-2022, 04:06 PM   #3
Nate2SS
Nate2SS's Avatar
Drives: 2011 Camaro SS LS3
When doing any cam there are several things you might want to change. With my car I did a BTR Stage 3 cam with chromoly pushrods at stock length and BTR 660" springs. I would also recommend doing trunnion upgrade, as well as a LS2 timing chain tensioner as well as a cam plate.
The tensioner, plate, and trunnion upgrade are more preventative parts to make sure everything stays together. I did not do the trunnion upgrade but I plan on putting the set I bought in sometime soon.
Make sure you get a good tune to go with it. Plenty of remote tuners on this site if needed.
2011 2SS/RS 6M: Hurst Short Throw Equipment, Speed Engineering Headers, Spectre CAI, BTR Stage 3 Camshaft 229/244 .630"/.615" 113+4, Chromoly Pushrods, .660" Springs with steel retainers.
Nate2SS is offline   Reply With Quote
Old 01-12-2022, 04:44 PM   #4
Scott S
Scott S
Drives: 2011 Camaro 2SS
Your also going to want bigger injectors, fuel pump or auxiliary fuel system with a ZL1 pump. LSA supercharger loves E85 also... Always measure for pushrods...
769HP/699 Torque LS3 heads ported and polished with BTR Spring kit & BTR Trunion upgrade, LSA supercharger ported by DC Porting, 102MM throttle Body, 2.40 pulley, Innovators West 10% Overdrive lower, BTR Stage 3 PDS Blower Cam, BTR timing chain kit, Mighty Mouse Catch Can, Flex Fuel kit, SMG Aux Fuel System, FIC 1000 Injectors, MGW Flat Stick Shifter, ARH 1 7/8 Headers, 3" X-pipe and Borla S-Type mufflers, ZL1 3:23 rear diff and Axles, 1LE suspension. Bmr Bushings in back. TUNING AND SPECIAL ALIGNMENT BY CARL @ CJ TUNES
Scott S is offline   Reply With Quote
Old 01-12-2022, 04:56 PM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Also not to forget, while you're in there and the front of the engine is apart, ya might want to upgrade your oil pump to a high volume Melling unit just for the added insurance. Wouldn't hurt.
Old 01-12-2022, 05:36 PM   #6
FASTFATBOY
Drives: 2013 ZL1
Put a 2.4 upper on it, you're gonna do it anyway. Put some ID 850 injectors in it and you also need a fuel pump. Always measure for pushrods, always.
I don't see the need for a trunion upgrade at .600 lift
I ran a .600 lift cam with the PAC 1218X springs with no issues.
Not mine, saved it years ago......
Here is the easy way to measure pushrods:
FWIW, EVERY cam install I have done using the LS7 lifter with a cam with greater than .600" lift (read smaller base circle) AND stock heads w/GM MLS gaskets has taken 7.425" pushrods for ~.050"-.060" preload. We measure lifter preload on each and every cam install we do. I have never had a lifter failure nor do we end up with the dreaded "sewing machine" noise.
Its very simple, If you change ANY of the following:
valve sizes, valve job, head milling, thinner/thicker head gaskets, decked block, cam with an altered base circle, etc... YOU MUST CHECK FOR PROPER PUSHROD LENGTH.
I have helped countless numbers of individuals with this process over the phone, via email, and PM's. I've posted the process on at least 3 occasions.
Here it is again in a nutshell:
1. Using the
EO/IC method, get the lifter to the base circle of the cam.
2. Using a known length pushrod (7.400" is a good start with stock rockers) run the rocker arm bolt down to zero lash. This is easily done with your fingers "wiggling" the rocker, the point at which the "slack" is just gone is zero lash.
3. Set your torque wrench to 22 lb./ft. Tighten the rocker to full torque and count the number of turns it takes to get there. 1 full turn wtih a stock 8mm X 1.25 bolt is ~.047" preload as measured at the pushrod/rocker interface.
4. I normally shoot for 1 1/4 to 1 3/4 turns with stock type lifters like Comp 850's, LS1, LS7 etc.
For an example, if you use a 7.400" pushrod and come up with 3/4 of a turn, you will need at least .025" longer pushrod to get into range. If you end up with 2 1/4 turns, you will need one .025" shorter...
I might not know everything but I will tell you that this method has worked for me year after year cam swap after cam swap. We average 3 cam swaps a week here so you can do the math.
If you are not familiar with the
EO/IC method for determining valve events in a 4 stroke engine, its very simple:
For a given cylinder as the Exhaust valve is Opening, the intake lifter will be on the base circle of the cam and lash/preload should be checked for that intake valve.
For a given cylinder as the Intake valve is Closing, the exhaust lifter will be on the base circle of the cam and lash/preload should be checked for that exhaust valve.
THIS METHOD ALWAYS WORKS!!!
Check it using the above method and see where you are.
Thanks,
2013 ZL1 M6, 2.4 pulley and a few bolt ons. 590 wheel and 11.70@122 on a hard tire.
FASTFATBOY is offline   Reply With Quote
Old 01-12-2022, 08:15 PM   #7
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
@FASTFATBOY - Thanks for posting that!! I have personally found it a serious PITA to use an actual pushrod length checker on LS motors....it could also just be me.
-Scott
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
