04-05-2014, 08:12 PM | #1 |
Does The Belly Pan Help or Hurt The ZL1....
I was just thinking that the pan was designed to help create down force.
Would removing it help in drag racing the car by removing engine bay Heat faster, and relieving the down force created by he pan help the car run faster. I don't track my car but would it affect daily and spirited driving without it? |
04-05-2014, 08:30 PM | #2 |
Native Floridian
Drives: 2014 - ZL1 / 2003 - Corvette Join Date: Oct 2013
The belly pan is for aerodynamics to make the air flow smoothly under the car - Not down force. Removing it will only slow your car down.
04-05-2014, 08:46 PM | #3 | |
I know this is true, but it also aids in forcing air out the hood extractor by enclosing the bay, it forces some of the air out the hood. According to GM's airflow video, airflow is forced out the extractor to create down force. Down force slows you down right? |
04-05-2014, 08:52 PM | #4 |
Drives: Love the one you're with Join Date: Sep 2009
So now you're going to re engineer this car after all the R&D that went into the design. Don't let the Z/28 fool you. The ZL1 is a bargain for us real people. It's way more real world car for the money.
04-05-2014, 09:00 PM | #5 | |
Drives: 13 ZL1 vert blac fastlane/LPE 750 Join Date: Jul 2011
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
04-05-2014, 09:06 PM | #6 | |
Not at all, just a question. I still have my pan on. Again the car was engineered for both the track and The strip. I believe the pan is engineered for the Track(IMO) to aid in aerodynamics. I think removing for Strip would net faster times, and allow the engine bay to remove heat faster. I could very well be wrong. I'm really not trying to reengineer anything, that's above my pay grade..lol |
04-05-2014, 09:16 PM | #7 | |
Native Floridian
04-05-2014, 11:32 PM | #8 |
Drives: 14 1LE Join Date: Mar 2013
The belly pan is strictly used to create downforce. Removing the pan will create lift in the front of the car, this would be a benefit for mileage and drag racing, it would be considered a negative for road courses. Cooling would also be improved.
LMS Engineering
04-05-2014, 11:38 PM | #9 |
Drives: SS 1LE Join Date: Nov 2012
Removing it will result in weight reduction with equals faster time.
04-05-2014, 11:42 PM | #10 |
Interesting idea. Why not see if someone will do some runs with and without and see if there is a time difference.
Todd in Vancouver
'14 ZL1 Camaro '67 Camaro SS Pro-tour in process How hard can it be... Check out my other build http://www.pro-touring.com/threads/9...ject-Obsession |
04-06-2014, 12:18 AM | #11 | |
This is exactly what I said and believe is true. Removing the pan would create lift which Would lighten the front end. The downforce would only benefit tracking the car, |
04-06-2014, 06:30 AM | #12 |
Native Floridian
It's a composite material, can't weigh more than 2 pounds, doubt removing it will result in a faster ET.
04-06-2014, 08:22 AM | #13 | |
I think what he really means is, well think of it like gravity vs weightlessness. The more of the forced gravity (downforce) you remove from the car the lighter it becomes. The lighter the car the faster the ET. In theory anyway. |
04-06-2014, 09:07 AM | #14 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
No, because weight is not the same as mass. The car still has the same mass, and will take the same amount of force to accelerate it. F=MA
Bryan 2018 ZL1 M6
