Emblempros
Old 10-19-2018, 12:00 PM   #1
Bildo
Bildo's Avatar
Drives: 2012 2SS/RS LS3
TSP PRC EHT Springs
Just a heads up buyers beware. Had a failure of a PRC EHT spring with less than 8k miles on it. Luckily it didn't completely drop the valve. I heard horror stories before about their springs, now I can confirm. These are supposed to be good for around 20k miles, mine were installed with the heads at 7k miles and didn't last to 15k.
2012 2SS M6, ERL Superdeck 6 427, PRC 255 Heads, Procharger F1A w/ 3.85 pulley, 1300hp intercooler, Squash Dual 450lph, E85, ID1700, RXT Clutch, DSS 1pc driveshaft, GForce axles, Eaton Detroit Trutrac, a bunch of other crap I don't feel like typing.
Bildo is offline   Reply With Quote
Old 10-19-2018, 12:04 PM   #2
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
Have you spoken to TSP? Be interestin to hear their take on it.
good luck!
peace
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 128K! - All work by me...
Old 10-19-2018, 12:14 PM   #3
Bildo
Bildo's Avatar
They offer a one year warranty on these parts. I have had these for well over one year. I just wouldn't buy any PRC branded springs ever again. PAC or BTR from now on. I will still do business with TSP for many things as they have always treated me right.
Old 10-19-2018, 12:39 PM   #4
Bildo
Bildo's Avatar
And I am probably ordering PAC replacements from TSP through my Tuner.
Old 10-19-2018, 07:07 PM   #5
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
BTR Platinum springs are all you need, priced right too!
zz430camaro is online now   Reply With Quote
Old 10-19-2018, 08:07 PM   #6
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
Ive got about 12k on mine. So far so good. I do however never rev my engine past 3k until oil temp is over 150*
Old 10-19-2018, 11:53 PM   #7
John_C
LSx FTW!!!
John_C's Avatar
Drives: 2010 Camaro 2SS RS
I run the TSP VVT 3.2 cam, TSP PAC polished 660's with Ti retainers, TSP 1.72:1 roller rocker arms in TFS GenX 255 heads.
With those rocker arms, my valve lift is almost at 660...
I rev to 6,800 rpm's all the time and during tuning my trans shifts, I have accidentally rev'd even higher.
No issues in over 10k miles.
2010 CGM Camaro 2SS RS A6 760rwhp on E85
Stage 2 ProCharger D1X
Circle D 3400 Converter
Kooks Jet Hot Ceramic Coated Headers
Kooks full true 3in exhaust
Trick Flow GenX 255's with Polished PAC .660's and Ti-retainers
Texas Speed VVT 3.2 cam kit w/DoD Delete
Texas Speed 1.72:1 Roller Rocker Arm Set
AEM X-Series OBDII Widebands
Fuel Injector Clinic ID1300 Injectors
GM ZL1 High Output Fuel Pump
DSX Tuning Flex Fuel Kit + E85
DSX Auxiliary Fuel System
JRE 6L80E Dipstick
NGK Iridium IX spark plugs #7 heat range
Mighty Mouse Camaro 5 Wild w/-12an and Billet Black
HP Tuners VCM Suite
John_C is offline   Reply With Quote
Old 10-20-2018, 05:53 AM   #8
Bo White
Bo White's Avatar
I shitt at 7200 at the track
Old 10-20-2018, 08:28 AM   #9
John_C
LSx FTW!!!
John_C's Avatar
What cam do you have that makes power all the way to 7,200 rpm's?
What supporting mods did you do? Oil pump?
JRE 6L80E Dipstick
HP Tuners VCM Suite
Old 10-20-2018, 09:41 AM   #10
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
Blown and stroked your lucky to not be buying more than new springs, watch out for mechanical overrevs they limit the life of the spring to jack squat. The tougher the spring the more the lift unfortunately the easier the break....Have no idea what your redline is or what...but most springs are only tested to 7k...….ls7 territory
2013 2SS/RS LS3 M6 ,CRT, NPP, Forged 428 ls3 stroker, GMPP ported heads, Katech chain, Mast windage, Cam Motion Cam, trunnion upgrade, Stainless Power headers HFC, CAI w/kit, Vmax PTD, Fluidampr25% udp, LPW diff cover, BMR strut brace,trailing arms, toes, bushings, Rocket racing wheels,Toyo Proxes 4+, elite catch can, clutch reservoir, dash/body LED, DRL rewire, Sparks billet badges, Forza 3way, tint, MRT louvers, ZL1 spoiler, MGW short throw, Monster dual LT1S clutch, bleeder, support, high vol pump, Speed hut shift light, ACC flames stripes, Driven ls30 oil, NGK TR6IX , Granatelli wires.
Old 10-20-2018, 12:30 PM   #11
Bo White
Bo White's Avatar
I have TSP 235/248-111 and PRC 260 13* heads
Old 10-20-2018, 01:33 PM   #12
Bildo
Bildo's Avatar
Replacing with PAC springs, TSP has contacted me and offered to make it right as well. I don't blame TSP at all.
Old 10-20-2018, 03:17 PM   #13
sinisterlsx510
sinisterlsx510's Avatar
Drives: 14 ss camaro summit white
Im on the same boat now! Debating whether to go pac springs or btr
2014 ss camaro
Stainless works long tubes , rotofab cai , vararam wedge , muffler delete,cat delete ,resonator delete , x pipe
2005 silverado 5.3
Long tubes, true dual bullets, aem intake , synergy tuned
2001 trans am
Lsx 408 ci rebuild in progress
1967 camaro
Sbc 327.
sinisterlsx510 is offline   Reply With Quote
Old 10-20-2018, 04:18 PM   #14
zz430camaro
Drives: 2015 1LE
I have a brand new set of springs from Livernois Motorsports you can buy from me. Believe they use PAC springs, PM me if interested, sell them pretty cheap, they were 400 new.
https://www.livernoismotorsports.com/product/LPP811112
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
