JDP Motorsports
Old 10-19-2018, 01:22 PM   #1
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Custom fab short runners intake.. Goertz1!
Just want to share my happyness!! I might have track time update soon if everything goes well!! Going to spin my 231 236 cam to 7300 and see what happens! Custom made to fit under stock hood.
TSP 231/236 111 cammed 1LE
WHAMMO is offline   Reply With Quote
Old 10-19-2018, 01:27 PM   #2
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2014 Camaro 1SS RS SIM
That's gonna be awesome, looks great!
2014 SS - L99 1SS/RS - "AleSSandra"
SSEssence is offline   Reply With Quote
Old 10-19-2018, 01:57 PM   #3
go_go_gadget88
go_go_gadget88's Avatar
Drives: 2010 Camaro 2SS/RS ABM 6M
Awesome man, looks fantastic!! Looks like it would be pretty similar in concept to the LOD X1. Curious to see how this turns out for you!
2010 Aqua Blue Metallic 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | Powell Bronze Trunnion bushings | 3.91's | BC Catch Can
go_go_gadget88 is offline   Reply With Quote
Old 10-19-2018, 02:10 PM   #4
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Yeah I cant wait to see that. Monday Im installing it. it has a big plenum and nice runner length!
I expect solid gains up top.
Old 10-19-2018, 03:00 PM   #5
go_go_gadget88
I've already had to come back and look at it 3 times now So pretty! Who's making this?
Any plans to dyno afterwards and see what it looks like vs your stock intake? I'm sure it pulls BIG up top!
Sticking with stock throttle body for now?
Old 10-19-2018, 03:18 PM   #6
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
It is AWESOME!! 😁😁😁 GOERTZ1 make those! Really a nice guy! Very skilled and honest.
I have a rod-mod/cleaned LS3 intake with a 90mm. I do not have a dyno with it, but I have track time, well mph will be the real data to look at since I couldnt 0-60' to save my life in street tires.
I switched to a 102mm inlet/TB on this intake. Im using a BBK 102mm. Pretty sure it will be badass. I expect 40hp and infinite carry uptop.
Old 10-19-2018, 03:25 PM   #7
13SSCamaro
13SSCamaro's Avatar
Drives: 2013 Camaro SS
that looks great, definitely interested in seeing the results
2013 SS M6, TSP Stage 3 231/246 cam kit, TSP Trunion upgrade, Cold Air Inductions CAI, VMAX PTB, TSP 1 7/8 Long tube headers and high flow cats, Corsa Xtreme ZL1 Catback exhaust, Elite E2-X Catch can, Trick Flow Gen-X 255 heads milled 0.025 and valve job, GPI rod mod and ported intake, 850 injectors,ZL1 fuel pump, Flex sensor and E-85 512rwhp/462rwtq
13SSCamaro is offline   Reply With Quote
Old 10-19-2018, 04:49 PM   #8
sinisterlsx510
sinisterlsx510's Avatar
Drives: 14 ss camaro summit white
Wouldnt the volume in the back runners hurt some gains?
2014 ss camaro
Stainless works long tubes , rotofab cai , vararam wedge , muffler delete,cat delete ,resonator delete , x pipe
2005 silverado 5.3
Long tubes, true dual bullets, aem intake , synergy tuned
2001 trans am
Lsx 408 ci rebuild in progress
1967 camaro
Sbc 327.
sinisterlsx510 is offline   Reply With Quote
Old 10-19-2018, 05:23 PM   #9
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Wow that's pretty neat looking dude !!I hope it does what you are looking for. Nicely done !!
TSP Stage 3 cam, 231/246@ 112 LSA,VMAX ported TB,K&N CAI,SP 1 7/8 LT'S, LOD X1 INTAKE, OFF ROAD MIDS,3 INCH FLOWMASTER ZL1 OUTLAW CATBACK,HOLLEY TALL VALVE COVERS,TAYLOR WIRES, ACCEL COILS,3200 PRECISION STALL,MPD COWL HOOD,Z28 FRONT SPLITTER,MPD SPOILER, HERITAGE FRONT GRILLE, TECHNOSTALGIA TAIL LIGHTS, PFADT 1.25 LOWERING SPRINGS, PEGASUS SOLID CRADLE BUSHINGS, KATZKINS CUSTOM INTERIOR, ALL INTERIOR TRIM AND UNDER HOOD TRIM ACCESSORIES PAINTED BY RIVER CITY CREATIONS RJT, FERRADA FR3 RIMS 20X10.5 FRONT,20X11.5 REAR,275/40/20 FRONT,315/35/20 REAR CONTI'S, 460RWHP,430RWTQ MUSTANG DYNO.
1JEWLDSSRS is online now   Reply With Quote
Old 10-19-2018, 08:28 PM   #10
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Maybe. Idk. You can see the LOD has a slope near the cowl, and their results seem really good. You have a max of 7.5inch max of clearance in the back, no miracle unless the cowl is cut. I think the slope is nicely done.
But it wont require to cut the cowl and wipers assembly like the Holley hi ram, which is a no go for me. 573ci of plenum. Hard to beat that and fit under the hood with proper runners, almost as long as the hi ram(which is my reference and hp/curve goal). I hope itll meet the LS3 hp/curve around 5800. The Sniper style intake meet hp at 6200 on every dyno Ive seen. That is on 376ci and surely havent seen it all.
I like the LOD X1 and almost pulled the trigger on it but had a nice deal on this Goertz1. I love the customized work and look.
Old 10-19-2018, 08:42 PM   #11
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Thanks. This is one of my biggest treat with this car !!
Old 10-22-2018, 12:22 PM   #12
J Rod
J Rod's Avatar
Drives: '14 BRM 1LE 2SS/RS
She's purty! Good luck with the results!
LSA swap in progress.... RotoFab CAI, Bo White TB, Coated SP 1-7/8" LTs, IKON Z28 Grill & Spoiler, Hero Tails - 424rwhp/410rwtq
J Rod is offline   Reply With Quote
Old 10-22-2018, 01:24 PM   #13
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Who did your Rod Mod Intake and what are you going to do with it after your swap?
Orange Krush II
1LE Front sway bar with DSE Sway Bar Links, Trailing Arms and Toe Rods, Splitter, and Axles, 14/15 Heat extractor, shocks and struts, Suede Flat bottom Steering wheel, short throw shifter with the Pegasus rear poly shifter mount, diffuser with dual mode mufflers, ZL1 Rockers, Belly Pan and pedals, Z/28 Intake, UCA Bushings,and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, C7 Z06 Vented Piston Calipers with CTS-V Rotors, PAFDT Solid Cradle bushing, 32mm JPSS Rear Bar, and Skip Shift eliminator. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 17/8 LTs.
Old 10-22-2018, 03:09 PM   #14
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Got the intake today. Pics comin!
I am looking to maybe or maybe not sell it wirh my ported TB. My IM and TB were done by Hiosilver, very very knowledgeable guy, to say the least. Ports were cleaned too.
Im ready to install! Need to assemble fuel setup but I have all the parts.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
