Old 02-23-2018, 09:08 PM   #1
bowtiesonly
bowtiesonly's Avatar
Drives: 2012 Camaro 2ss
c6 zo6 wheel 18x9.5 tire size?
Hey about to get a set of c6 z06 wheels for a drag setup for the wknd, was wondering what size of drag tire i need to run to stay equivalent to the factory tire size ? thanks for any help, not very fluent in tire talk.
2012 2ss , long tube headers , summit x pipe ,borla mufflers, vararam intake, vmax ported throttle body rdp motorsports dynosteve tuned, BMR trailing arms and bushings elite engineering catch can. [Ifirst camaro ]2012 LT LFX, nytrex wet system ,GPI dyno tune, Injen longtube intake, Dynomax axle back exhaust, Vmax ported throttle body, elite engineering catch can.
bowtiesonly is offline   Reply With Quote
Old 02-23-2018, 09:22 PM   #2
briancamaross
briancamaross's Avatar
Drives: 2011 ss 2ss auto camaro
305/45/18 is a 28.7 tire same as stock
2011 2ss white Camaro mods are texas speed stage 4 cam 235/239 Texas speed 2inch headers no cats magna flow bullet mufflers gpi rod mod ,circle d 4000-4200 5c stall. 3.91 gears vararm cai power wedge.
briancamaross is offline   Reply With Quote
Old 02-23-2018, 10:15 PM   #3
bowtiesonly
Awesome thanks , will factory lugs work on the c6 wheels?
Old 02-23-2018, 10:40 PM   #4
U LUZE
U LUZE's Avatar
Drives: 2012 ZL1
I used the factory lugs on the Z06 replicas.
~ 2012 ZL1 - DynaTech 1 7/8" Headers - ID 1050 Injectors - E85 - DSX Aux Pump -
22.5% Crank Pulley - Roto-Fab CAI w/ Big Gulp-
CJ/Jannetty Tuned ~ PB ET 10.54
U LUZE is offline   Reply With Quote
Old 02-24-2018, 07:07 AM   #5
bowtiesonly
Sweet that's what I was hoping! Do you have tpms in your setup? Can I just run without the sensors? Won't affect anything?
Old 02-24-2018, 07:16 AM   #6
briancamaross
I have them but I also have a set of spare c6 zr1 wheels 18x9.5 my spares won’t have the tpms
Old 02-24-2018, 10:11 AM   #7
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
How much do those weigh?
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 02-24-2018, 12:46 PM   #8
briancamaross
Mine weight 23 each
