11-13-2020, 04:32 PM | #1 |
It is the year...
Removing Front Plate Bracket w/ Metal Rivets
Hey guys,
Got a new replacement Camaro and it came with a front plate. Attached with rivets. Plan is to drill out and fill with Bumper Plugs. I saw this thread and will be doing a version of that how to: https://www.camaro5.com/forums/showthread.php?t=160323 However... My rivets still have the mandrel part attached on 3 of 4. They are supposed to snap off and come out when you install them. Look cut. Any suggestions on how to remove those other than trying to drill thru them? Any other suggestions on removal? This was bought recently from an independent dealer, and I'm the third owner. Original purchaser was in a state that needed it. So just gotta deal with it now.
11-13-2020, 05:38 PM | #2 |
Take a punch the size of the pin and tap them back. Then use a drill bit just slightly larger than the pin the drill just enough to pop the rivet head off. Then you can punch the entire rivet(minus the head) within messing up the bumper holes. This is one technique used in the aviation world.
You might have to step up your bit size to get just the right size to pop the head off without tearing up the hole. Just get a good sharp bit and let it do the work so you don’t spin the entire rivet. |
11-13-2020, 05:41 PM | #3 | |
It is the year...
01-27-2021, 07:55 PM | #4 |
Drives: 2013 Camaro SS Join Date: Jan 2020
Its not easy. I used body trim plugs wrapped in vinyl to patch the holes. Posted a diy on here somewhere. I did patch one with jbweld plastic and touch up paint and it actually looks pretty good.
2013 2SS Blue Ray Metallic/Silver stripes, black Interior. Halo conversion, Diode Dynamics grill lighting, LED interior and fog lights. Sundown 8" DVC, Altrend 300.1 Amp, Handmade side-mount box. Soon to be BBK Headers and hi-flow cats.
02-03-2021, 02:16 PM | #5 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Not a fan of the plug look. I had mine filled and repainted by a shop. I recommend this for much more appealing look.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
02-03-2021, 02:45 PM | #6 |
Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
BLU DUCE AKA=Spike III Build
+1
