10-16-2021, 07:57 AM | #15 | |
10-16-2021, 03:50 PM | #16 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
Care to explain the misinformation or correctly state the procedure?
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
10-16-2021, 04:20 PM | #17 | |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
If I understood correctly, the first press - will turn off the traction control, but the stabilization system will still be active. The second press also switches off the stabilization system. And holding the button for 8 seconds turns off the "rest" of the assistants. I just wonder what the "rest" is.
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune. |
10-16-2021, 05:29 PM | #18 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
I believe the double press for competitive mode allows more slide but doesn't completely kill stabilitrak, it will still interfere at extremes. Push and hold turns it off completely.
10-16-2021, 06:24 PM | #19 | |
10-16-2021, 06:27 PM | #20 |
Nah, when it is off, it is off. When I was first playing with it way back when and I disabled the stabilitrac and traction control and was in a huge parking lot, I had NO control of the car what so ever, it did whatever it wanted to without any interference or assistance from the computer or ABS...
10-17-2021, 09:34 AM | #21 |
GrINned & JUICEd
From a 2010 2SS, 6 speed mt manual.
10-18-2021, 08:42 AM | #22 |
Drives: 2011 Camaro SS LS3 Join Date: Oct 2020
Was launch control offered in early 5th gens? I thought that feature wasn't more common until late 2011 early 2012?
10-18-2021, 10:10 AM | #23 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
It's on my 2010, or at least prior to changing the tune, it would not rev past 4k if you held the clutch down in gear.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
10-18-2021, 10:39 PM | #24 |
GrINned & JUICEd
On my 2010. It held at 4.5k. I may have launched once or twice. Use CTAP now.
