Old 06-21-2018, 08:58 PM   #1
moyn
M0yn
Drives: 2011 Camaro Inferno Orange Metallic
Leak passenger side of engine
So, I found a leak on the passenger side of my engine. The hose clamp broke. But I have no idea what the hose is for. Or what clamp/part to buy to fix it.
Any help would be appreciated. And if you think this is a DIY or a take it to the shop type fix.
I know for sure the clamp is broken. Somehow even with my driving the broken part stayed on the frame. But it’s hard to tell if anything else is broken. Or if the fluid is just on the outside of everything. And can anyone help me to know what fluid is inside this hose?
moyn is offline   Reply With Quote
Old 06-21-2018, 11:24 PM   #2
VASCAR2
VASCAR2's Avatar
Drives: 94 Camaro, 10 1LT IBM Camaro
Looks like a radiator hose clamp broke and the rust is because some of newer antifreeze is pretty corrosive. Your coolant level might be low. The hose will have to removed to place a new clamp on the hose.
If this was my car I'd probably inspect the hose and if is soft or bulging I'd probably replace the hose and have the radiator and cooling system flushed. My Camaro will be nine years old this September so mine could stand being flushed.
You can replace the clamp and top off the coolant which would be the cheapest route.
VASCAR2 is offline   Reply With Quote
Old 06-22-2018, 04:14 AM   #3
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
All correct.
I just replaced my upper and lower hoses a month ago, along with most of the fluid. It was time as I had over 110K miles and 8 years old. While there I change the serpentine belt too.
Old 06-22-2018, 06:09 AM   #4
moyn
M0yn
Thanks guys! Hopefully Autozone has a clamp for me and I’ll give that a try
Old 06-22-2018, 06:17 AM   #5
motorhead
Just get a stainless band clamp at any hardware, plumbing supply or home improvement store. You wont even need to remove the hose to install it then.
Old 06-22-2018, 07:26 AM   #6
moyn
M0yn
That’s exactly what they had there for me!
Old 06-22-2018, 12:22 PM   #7
JJPlace1
JJPlace1's Avatar
Drives: 2010 2LT Victory Red
You really do not have to remove the hose , just unclamp the clamp completely ( keep turning left ) and restart around the hose once the old clamp has been removed !
Previous Vehicles
1970 Impala 2D 350/300
1972 Buick GS 350
1967 Pontiac Firebird 326
1969 Chevelle SS 396/375 I really miss this one
1966 Chevelle SS 396/350
1978 Plymouth Fury 440
1982 VW Scirocco ( Got married )
1987 VW Scirocco
1992 Ford Taurus V6
1996 Dodge Intrepid
2002 Dodge Intrepid
2002 Mercedes ML500
2010 Camaro 2LT
JJPlace1 is offline   Reply With Quote
