03-07-2013, 02:10 PM | #1 |
Heat cycling drag radials?????
Getting ready to purchase Nitto NT05R... Representative asked if I wanted them heat cycled??? Never heard of that before, so thought I'd ask... They say will get better performance and tread life out of them if they are heat cycled properly... They wanted 30 bucks to do both....
1) is this true 2) if it is beneficial is it worth 30 bucks for them to do it??? Any input is GREATLY APPRECIATED!!!!!
Sit Back and Enjoy The Ride!!
03-07-2013, 03:12 PM | #2 |
Drives: 2010 CAMARO 850 RWHP/733 RWTQ Join Date: Sep 2010
I heat cycled my NTO5's at the track LOL.. But yes I would like to hear if this heat cycle works...
*Night Fury
*Vortec YSI *Alky Meth *RPM TH400 with Brake *Precision 3600 Converter *850 RWHP/733 RWTQ |
03-07-2013, 03:24 PM | #3 |
Drives: 2010 Camaro Join Date: Feb 2010
Heat cycling bonds the molecules in the rubber.
Any DOT race tire is extremely sensitive to the first heat cycle of its use. The first heat cycle can determine performance and wear characteristics. The compounds in a new race tire are “green” and its chemical make up is not fully stabilized. During the first heat cycle, the tread compound stretches as it heats. The heat can also cause changes at the molecular level. During a heat cycle, bonds are broken and reformed that help to make the tread compound more stable. The benefit of this process is a tread compound that lasts longer and provides better traction. However, if the first cycle is not performed correctly, the tread may develop irregular compounding, leading to poor wear and inconsistent traction. Some racers try to heat cycle their own tires, with mixed results. This involves bringing the tires up to race temperatures and then “resting” them for 24 to 48 hours while off the vehicle. This process can be inconsistent as the tires may not heat evenly on the four corners of the car. Also, temperatures across the tread face are not always uniform due to camber and scrub. Plus, if this is the owner’s only set of tires, it is inconvenient to mount and dismount the tires before using them to race. Some DOT race tire suppliers offer heat cycling services, and use machines that heat the tire by applying a load (no artificial heat). These systems generate uniform temperature build up throughout the tread, a condition not achievable on the track. Because there is no cornering involved, there is lateral scrubbing and virtually no loss of tread during the heat cycling. |
03-07-2013, 03:58 PM | #4 |
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega Join Date: Mar 2012
^^^ So the short answer is no.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
03-07-2013, 04:06 PM | #5 | |
Banned
Drives: gen5 Join Date: Mar 2013
03-07-2013, 04:08 PM | #6 |
03-07-2013, 04:58 PM | #7 |
Drives: Fire Engine Join Date: Oct 2008
I think the answer is:
1) Yes. 2) Yes.
12.618 @ 110.75 Bone Stock 1/4 mile
8.165 @ 86.52 Bone Stock 1/8 mile 11.189 @ 124.44 on a 1.73 60' TVS2300 3.4 pulley, JRE tuned, Kooks LT headers and HF cats, MBRP catback exhaust, CAI intake, ADM scoop. Stock wheels/tires. Sold |
03-07-2013, 05:02 PM | #8 |
Lmao!!!! Ty for the information! Sounds like that's the way to go then! Gonna order them tomorrow!
03-07-2013, 05:26 PM | #9 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
Ha. Never heard of this.
Sent from my PC36100 using Tapatalk 2
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
03-08-2013, 06:18 AM | #10 |
www.1baddogracing.com
Drives: 2010 IOM 2SS/RS Auto Join Date: Apr 2011
+2 Slicks maybe on high power car. DR not so sure.
2010 Camaro 2SS/RS Aqua Blue Metalllic (bolt-ons)
2020 Camaro 2SS/RS Satin Steel Metallic - Shock and Steel Edition 1 of 98 - A10 (bolt-ons) 2010 Camaro 2SS/RS IOM - 1,023 RWHP 813RWTQ (Previous Paxton Record Holder: 9.82@139) Built and Tuned by Heintz Racing Go: DSS 9", RPM Trans TH400, Carlyle Racing 15" Conversion, ECS Vortech YSI-B, Fore Fuel System, ID1700, Gall Racing 427 C.I LSX, Mast 285CC Heads, HR Custom Cam Show: Custom Painted Stripes/Badges (Orange Pearl over White), Z/TA Spoiler, VFN Hood, Weld Wheels http://www.HeintzRacing.com http://www.youtube.com/user/1baddogracing |
