12-03-2013, 10:26 PM | #1 |
JT Synergy RS/2SS
Drives: 2011 Camaro RS/2SS (L99) Synergy Join Date: May 2013
Difference in drag radial overall height
Hey guys,
I'm probably going to get 275/45R18 M&H drag radials and plan to keep my stock 20's up front for drag racing. I realize that many guys are running this combo and I wanted to know if the 1" overall height difference will cause any issues? Will my tuner need to account for this or is this not enough of a height difference to worry about? I only visit the track 3 or 4 times a year. What are you guys doing? Thanks! |
12-04-2013, 06:29 AM | #2 |
Actually, you're the first person I've EVER heard of running those tires!!! Most folks run a 305/45R18 (same height as stock). Technically, no, it shouldn't cause a problem, but I've read many stories about some cars that are either more or less sensitive to the tire height difference. If it does cause a problem, it will just be "lights" on the dash, and will reset itself once you switch the tires/wheels back out.
12-04-2013, 06:36 AM | #3 |
Only drives on Sundays
Drives: '16 2SS A8 NPP MRC NGray Join Date: Feb 2011
You can change the diameter of the tires in the tune. This will help keep your speedo and your shift points accurate, so if your tuner is in the tune anyway, it's simple to do.
Padre |
12-04-2013, 08:28 AM | #4 |
JT Synergy RS/2SS
Ok, thanks guys!
12-04-2013, 10:25 AM | #5 |
Drives: 2010 Camaro Auto Join Date: Mar 2010
You shouldn't have any problems. I ran nitto NT05R 285/40/18's that properly inflated are only 26". I ran them at 18 psi which took them below 26". I never threw any codes or had any issues with the stabiltrac.
Just livin' life |
12-04-2013, 11:09 AM | #6 |
JT Synergy RS/2SS
Did you have your tuner adjust for the shorter tire or shift point changes?
12-04-2013, 02:25 PM | #7 |
Drives: 2011camaro SS Join Date: Nov 2012
The difference in tire size will slightly affect your shift points if you are already tuned for a stock height tire. I just did this exact same thing yesterday but I went from a 26.5 rear back up to 28". Took my tuner less than a min to key in the tire size and update that in my tune. If he has already did your work for you will all ur mods, I would think he would do this just as a good appreciation token. If he charges you $100 to do it, then you have 2 choices, pay it (which IMO is ridiculous) or tap shift it urself at the track, being that you only go a few times a yr.
it might not even need adjusting. Just depends on where you are tuned to shift at now vs the difference in tire size. What are ur shift points now and how high do you cross the finish line? |
12-04-2013, 04:15 PM | #8 | |
JT Synergy RS/2SS
12-04-2013, 05:54 PM | #9 |
If you have plenty of gear left then you will be fine. He might need to adjust your tire size difference Bc now it will be a little off but 1" is barely going to be noticeable.
If you are going to buy new tires, why not run what most guys run which is the 305/45/18? Then your tune is the same Bc ur tires will be same height as stock. |
12-04-2013, 07:10 PM | #10 | |
JT Synergy RS/2SS
12-04-2013, 07:49 PM | #11 |
Drives: none Join Date: Aug 2011
The M/T 305 is 32lbs per tire, and the 275 M&H is 29.9lbs per tire.
The difference from the stock height 28.8" tire to the 28" M&H is going to be negligible, and since your car is a 2011 the only shift it's going to affect is the 1-2 shift since that's the only one that is based only off of MPH. The 1-2 shift should be about 150rpm higher with the 28" tire if your tune is based off of a 28.8" tire height. So 6550ish instead of 6400. 2-3 and 3-4 should shift based off of RPM, so they should still happen around 6400rpm. |
12-04-2013, 08:07 PM | #12 | |
JT Synergy RS/2SS
12-04-2013, 08:59 PM | #13 | |
Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
12-04-2013, 09:07 PM | #14 |
having FUN now 13.66@101
The other issue you might experience is a total shut down of all stabil trak,, traction control and abs systems.
I run a smaller dia. rear drag radial and the system senses there is an issue with a difference in tire dia. Not sure when this occurs, but I thought I read somewhere it is close to 1" difference and you are close to that. Certainly does not hurt, but the dash will light up like it is Christmas, you will not have accurate readings. I drive from home to the track and back again with my set-up running a 265/40/18 rear tire.
